One more 4P1L SE
One more 4P1L SE
Old 23rd February 2011, 02:13 AM   #21
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
Tried 10W transformers Utah 7390. Total merde... Bass is Ok down to 40 Hz on full power, below it starts saturating. But -3 dB is on 5 KHz already... I have a pair from Grundig stereo radio, will try them.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 23rd February 2011, 08:33 PM   #22
hihopes is offline hihopes  South Africa
Default Sockets for 4p1l
I've had my eye on these 4p1L's for some time now, and your endorsement has finally persuaded me to order some. I have 10 on the way. I want to build a SE preamp, then a simple as possible push-pull power amp with them. Can you recommend a good source for reasonably priced sockets for them?
William.
Old 23rd February 2011, 10:29 PM   #23
Wavebourn's Avatar
One more 4P1L SE
Hi William;
I myself am looking for source of sockets for them. However, there are plenty of Chinese sockets on epay, but I have bad experience with 9-pin sockets from there that had contacts made of soft metal, they are like disposable... I had 3 original Russian military sockets, used 2 of them. Don't know where to get more. Russian sockets for loctal tubes I see on epay now are shielded, 4P1L beauty would be invisible inside of them, and it would be hard to swap tubes. One option I consider is to remove sockets from shields and solder them on PCB.
Old 23rd February 2011, 11:03 PM   #24
Wavebourn's Avatar
One more 4P1L SE
I tried now with 5W output transformers from Grundig stereo radio. Results are even worse: they can't pass 2.5W on frequencies below 60 Hz, start saturating... Edcor 25W 5K:8 Ohm are still winners, but they are huge, like 100W transformers I use in my Pyramids.
What other OT options do I have? XSE15-8-4.5K? Or GXSE15-8-5K? Did anybody try them?
Old 23rd February 2011, 11:33 PM   #25
quikie22 is offline quikie22  Malaysia
just ordered some Chinese sockets on epay..... will let you guys know the quality. the sockets seem to cost more than the tubes.
Old 24th February 2011, 06:47 PM   #26
That seems to be the way it works. I had hoped somebody had found an economical source for them. Did you order the ones that are $9.99 for 4 with free shipping?
Old 24th February 2011, 06:51 PM   #27
woodturner-fran is offline woodturner-fran  Ireland
The little dot amp use oddball driver tubes.... 1k5 I think......
Old 24th February 2011, 07:22 PM   #28
Wavebourn's Avatar
One more 4P1L SE
What is 1k5?
Old 24th February 2011, 07:34 PM   #29
1k5 = directly heated pentode by the look of it.
Old 24th February 2011, 07:54 PM   #30
Wavebourn's Avatar
One more 4P1L SE
Ah, yes. According to plate curves indeed plate resistance is 1k5
Speaking of oddball tubes, tubes you have available may be oddball to me.
I have lots of 6J5P, curves in triode mode are there:
6N16B was made for military as a tiny replacement for 6N1P. It is not most linear tube, but for loaded on CCS cathode follower it is more than adequate.
If 6J5P is oddball for you, you may replace it by analogs, like Russian 6J4, or American 6AH6 or 6AC7, they are all the same.
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
