One more 4P1L SE
One more 4P1L SE
Old 17th July 2012, 08:14 PM   #201
Deco-Doctor is offline Deco-Doctor  United Kingdom
Originally Posted by andyjevans View Post
Deco-doctor
Have a look at the 126B and 126C at Bluebell Audio - look at Transformers > Interstages. They are exactly the same price as Danbury and probably at least twice as good. Also they are bifilar wound and have a known and stated inductance. Philip at Bluebell is very helpful and knows his tubes.
Hi Andy
Thanks for your thoughts. I am already using Hammond 126A interstage in my 45 SE amplifier. I use a triode strapped D3a input/driver running at 160V 12mA. And yes the 126 series are super value. The square wave response is astonishingly good.
I could try the 126A as a load for the 4P1L at up to 15mA if it sounds as good as you say at low current.
Martin
Old 17th July 2012, 08:53 PM   #202
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
Originally Posted by Deco-Doctor View Post
OK I take your point, but my question is what is the plate resistance of a single 4P1L at the chosen operating point?
There are some curves posted in this thread. You can take a ruler, measure and divide dV/dI
The Devil is not so terrible as his math model is!
Old 17th July 2012, 10:12 PM   #203
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
One more 4P1L SE
About 1100-1200 subject to filament starvation:
4?1?/4P1L triode curves | Bartola Valves
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 17th July 2012, 10:17 PM   #204
mogliaa's Avatar
One more 4P1L SE
Originally Posted by revintage View Post
Hey Ale,
At what load did you get the sweet spot?
Hi Lars,
I run the preamp at 90V, 20mA and about -4V in filament bias with slight filament starvation at about 500-530mA. I did play around quite a lot. Recently found that is more linear at bias greater than -10V providing you don't exceed anode voltage limits. But haven;t tested how it sounds in this region.
Definitely likes it working about 15mA where possible.
You can read some of the learning experience here:
4P1L DHT Line Stage
Cheers
ale
Old 17th July 2012, 10:29 PM   #205
Some good curve traces here:-
Tube Tester Files - 4P1L
Old 17th July 2012, 11:22 PM   #206
Wavebourn's Avatar
One more 4P1L SE
Yes, they are good. But his curve tracer can't be trusted on positive g1 voltages, though to answer your question it is not required.
Old 18th July 2012, 12:48 AM   #207
andyjevans is offline andyjevans  United Kingdom
Originally Posted by mogliaa View Post
Hi Lars,
Cheers
ale
Hi Ale - what was the value of your cathode resistor in filament bias?
I'm playing around with cathode resistors and trying to find the right value right now. I won't know what different currents sound like until I get my setup working properly. It may sound better at higher currents like everyone says. The 4P1L drivers are running at more like 17mA in my PP 6C4C amp (26 inputs), and that sounds the best of all. Filament bias in SE is a different story.
Andy
Old 18th July 2012, 12:51 AM   #208
Wavebourn's Avatar
One more 4P1L SE
Try 12 Ohm if your filaments are paralleled (about 1A current through them)
Old 18th July 2012, 07:45 AM   #209
mogliaa's Avatar
One more 4P1L SE
Andy,
I used two ww 15 ohm resistors in parallel that I had at hand
Old 18th July 2012, 08:40 AM   #210
revintage is offline revintage
Hey Ale,
You still didnīt answer into what load you found the sweet spot. Unloaded?
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 06:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 08:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 06:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 06:36 PM
