One more 4P1L SE
One more 4P1L SE
Old 24th March 2011, 06:10 PM   #141
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by Wavebourn View Post
By the way, here is a rear panel: speaker outpurs, 4 switchable inputs in the left corner, and in the right corner inputs for MC and MM, with a switch between them. I decided to use a 5-pin female XLR for MC input. MC input will be balanced.
Do you know if some standard for XLR inputs for MC phono exist?
Pin Function
1 Chassis ground (cable shield)
2 Positive polarity terminal (hot)
3 Return terminal[4] (cold)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 24th March 2011, 07:06 PM   #142
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
Originally Posted by Helmuth View Post
Pin Function
Thank you Helmuth;
I mean 5 pin XLR for balanced stereo ins from MC head.
Nooks like no standard exist, so I will invent mine.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th March 2011, 10:47 PM   #143
simon7000 is offline simon7000  United States
These are the common ways they are hooked up
3 pin 1 gnd 2 hot 3 return
4 pin 1 gnd 2 return 3 in between 4 hot
5 pin 1 gnd 2 return L 3 hot L 4 return R 5 hot R
or 5 pin 1 gnd 2 hot in 3 return in 4 return out 5 hot out (prevents feedback)
6 pin 1 gnd 2 return A 3 hot A 4 return B 5 hot B 6 unbal in
ES
Old 25th March 2011, 12:30 AM   #144
Wavebourn's Avatar
One more 4P1L SE
Thank you Simon!
Old 9th May 2011, 06:47 PM   #145
Wavebourn's Avatar
One more 4P1L SE
A month ago local audiophiles were impressed by sound of this amp.
We used this speakers to try it:
The sound was very natural, clean and detailed. However, such speakers require at least 10W of power to be happy, but for more effective speakers it is the killer amp.
Edit: despite of common beliefs, audiophiles absolutely did not react on presence of semiconductors and absence of an interstage transformers. They did not ask about resistors and capacitors. They asked about tubes and transformers, though, demonstrating understanding of linearity, smoothness, distortions (non-linear and frequency & phase response). All attention they paid on sound quality.
Old 10th May 2011, 07:15 PM   #146
Wavebourn's Avatar
One more 4P1L SE
Last schematic, attached
Old 27th May 2011, 08:25 PM   #147
mogliaa is online now mogliaa  United Kingdom
mogliaa's Avatar
One more 4P1L SE
Hi Anatoly,
Congratulations for this superb design. I'm sure you're enjoying it!
I've traced the 4P1L triode strapped anode curves (see attached).
What is the bias point in your design?
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 4th June 2011, 10:13 PM   #148
ratbagp is offline ratbagp  United States
I need a little help with a 4P1L line stage I am building. From the various plate curves I've seen I'm aiming at roughly 150 volts plate, 15 ma and -15 volts bias. The plate load is a a couple of cascoded DN2540's per channel similar to
Tube DIY Asylum - RE: Hooked up the Ixys IC CCS tonight - preliminary results - Tre' - July 11, 2009 at 22:13:45
The output of the ccs is connected to pins, 2, 3, 4.
The mu output of the ccs connects to a 2uf cap and thence to the output rcs socket.
I'm using a regulated 3.9 volt DC supply to power the heaters (pins 1 & 7). The supply is floating (simple LM317 to start with). I've got a 47uf cap across pins 1 & 7.
I've got a 1k cathode resistor to ground from pin 8. I figure that should give 15 volts bias at 15 ma.
The heater supply is working as I expect.
I've got 280 volts on top of the CCS. There is about a 10 volt drop across the ccs with about 270 volts on the plate, obviously not what I want.
I'm not getting any bias voltage from pin 8 to ground which is where I'm expecting about 15 volts. Same in both channels, so I presumably have wired something incorrectly.
Any ideas?
ray
Old 4th June 2011, 10:24 PM   #149
Wavebourn's Avatar
One more 4P1L SE
Hi Ale;
Originally Posted by mogliaa View Post
Hi Anatoly,
220V A-K, -17V G1-K, 50 MA per tube. 5 W from paralleled pair. They are easy to parallel due to linearity and consistence.
Edit: sorry for late answer, I was in Az, at Grand Canyon then, and have not seen your posting.
May I add your graph to my page?
Old 4th June 2011, 10:31 PM   #150
Wavebourn's Avatar
One more 4P1L SE
Any ideas?
Hi Ray;
it looks like you've got absolutely dead tube. Even with 3.9V on filament instead of 4.2V it should draw enough of current.
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 06:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 08:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 06:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 06:36 PM
