One more 4P1L SE
One more 4P1L SE
Old 18th March 2011, 11:55 PM   #131
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
Originally Posted by azazello View Post
Анатолий, amazing!!
Thank you Никола!
The Devil is not so terrible as his math model is!
Old 19th March 2011, 01:14 AM   #132
kmaier is offline kmaier  United States
kmaier's Avatar
Originally Posted by Wavebourn View Post
I wonder, how good is adhesion of mirror finish to Lexan: I think about gluing the plastic mirror between hot toobs and transformers, so no bolts would be visible...
Any experience?
Try this stuff: 3M Transfer Tape 467MP
I use the 2.0 mil stuff (200MP) to apply anti-rattle plates to brake pads. They haven't moved yet.
3M? Adhesive Transfer Tape 467MP
Regards, KM
... just because you're paranoid, it doesn't mean they're not after you...
Old 19th March 2011, 01:24 AM   #133
Wavebourn's Avatar
One more 4P1L SE
Thank you KM! I will save this information. For the current project Velcro works better; in case I need to replace some transformer I will need to remove the mirror.
Old 21st March 2011, 01:52 PM   #134
hihopes is offline hihopes  South Africa
Quote:- "Now I need to make that +12V stabilizer, and increase voltage of the negative stabilizer."
How about using 7 x cheap red LED's @ around 10mA?
Also, do you have an updated schematic and if so, would you please post it?
Old 21st March 2011, 07:15 PM   #135
Wavebourn's Avatar
One more 4P1L SE
The schematic is still the same, except 6J9P trioded instead of 6N16B paralleled, and one more 4P1L in parallel to the existing one (including filament voltage drop resistor and bias control resistor), and 2K4 transformer instead of 5K transformer.
Speaking of 3'rd grid bias, I decided to go without it, since 1'st drive by cathode follower is adequate.
Old 21st March 2011, 08:08 PM   #136
I thought you said 3rd grid bias increased linearity? Or was it an insignificant difference?
Old 21st March 2011, 08:12 PM   #137
Wavebourn's Avatar
One more 4P1L SE
It increased linearity with less positive 1'st grid drive needed, but requires higher negative bias of the 1'st grid. The amp sounds nice without this trick, so I decided not to deal with such complications: I have limited negative voltage supply. May be I will try it later, carefully measure and compare results.
Old 21st March 2011, 08:32 PM   #138
OK, thanks for the explanation. Will you run measurements on the amp eventually?
Old 21st March 2011, 09:21 PM   #139
Wavebourn's Avatar
One more 4P1L SE
Yes!
But before that, I have to finish input selector, attenuator, remote control, and phono stage.
Old 24th March 2011, 04:02 AM   #140
Wavebourn's Avatar
One more 4P1L SE
By the way, here is a rear panel: speaker outpurs, 4 switchable inputs in the left corner, and in the right corner inputs for MC and MM, with a switch between them. I decided to use a 5-pin female XLR for MC input. MC input will be balanced.
Do you know if some standard for XLR inputs for MC phono exist?
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 06:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 02:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 08:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 06:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 06:36 PM
Copyright ©1999-2017 diyAudio
