diyAudio Sponsor
Old 13th February 2011, 05:24 PM   #1
Default 6N1P and 6N6P OTL headphone amp
Hi all!
This is one of my last valve project. An OTL headphone amp with a 6N1P in ground cathode for input stage and a 6N6P in SRPP for the output stage.
I've found that the best working point for this tubes are 10 ma for the 6N1P and 22 ma for the 6N6P. The circuit is a classic and in the next post I'll send to you. With my Sennheiser HD590 and AKG K271 Mk2 works really fine, what a sound!!! I have a slight and impercectible hum but I soon resolve it with a choke in the PSU, now I have a CRC cell but it's bettere a CLC; next step.
The case is a bit ugly but I have used some recycled waste from my factory (rivets... like a Douglas DC3... could be a new trend???)
I bought a lot of russian valves on ebay, different factories and years and works really fine, great sound and incredible price, I'm working with them in my next project: a RIAA-LINE preamplifier.
ciao
Old 13th February 2011, 05:55 PM   #2
Stixx is offline Stixx  Germany
Stixx's Avatar
That's quite a nice build, and I do like the rivets...
Will you post a schematic (since I have made a schematic for 6N23P-6N6P myself ?
Just being curious...
Old 13th February 2011, 09:57 PM   #3
HollowState's Avatar
Man, that chassis's built like a tank. Half inch thick (?) with pop rivets into a blind hole?
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 14th February 2011, 02:25 AM   #4
miklos is offline miklos  Canada
Might be tubes.
miklos
Old 14th February 2011, 09:13 PM   #5
orson56 is offline orson56  Italy
Default Here the schematic
Originally Posted by orson1956 View Post
Hi all!
ciao
Old 28th September 2011, 06:55 PM   #6
arche13 is offline arche13  France
Hello
I wish to build this amplifier,
But I have a helmet Grado sr60 impedance 32 ohms.
Work you he(it) with no problem at all or is it necessary to make modifications?
Cordially
Old 28th September 2011, 06:56 PM   #7
Hello
Cordially
Old 28th September 2011, 07:37 PM   #8
Would it give even lower output impedance if both 6N6P halves were connected in parallel and as a cathode follower instead of SRPP ?
There is also quite high overall gain. Is that much really required ?
Old 28th September 2011, 09:46 PM   #9
ruffrecords's Avatar
Which headphones do you use?
Cheers
Ian
Ian
Old 26th January 2012, 08:30 PM   #10
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Very nice, how much did the amp cost you to build? How does it sound?
If you have the power supply schematics, please post it as well.
Headwize 6N1P OTL headphone amp having hum mr_push_pull Tubes / Valves 39 4th July 2011 08:43 AM
Aikido 9pin with 6n1p and 6n6p as Headphone eeyore Tubes / Valves 7 8th November 2010 01:49 PM
FS: Indeed 6N1P headphone amp Bengali Swap Meet 0 4th November 2010 05:24 PM
Sub 6n6p for 6n1p? toufu Tubes / Valves 3 22nd April 2010 04:43 AM
Need a little help with Aikido 6n1p/6n6p S.Spielbergo Tubes / Valves 3 17th June 2009 02:09 AM
Page generated in 0.10229 seconds (80.49% PHP - 19.51% MySQL) with 11 queries
