| diyAudio Sponsor | ||
#11 |
Capacitors K42 is not the best, K40 would be better.
Assessing the impact of coupling capacitors in the audio amplifier. http://www.magictubes.ru/ves/kondens.htm |
#12 |
Is there any danger in using this kind of headphone amplifier? I mean ... you could have 300V near your brain in case something goes wrong... I'm asking because I talked with a friend about such an amplifier and he was a little bit reserved about it ...
#13 |
What specs are the power transformer? and where from?
Thanks |
#14 |
R4 & R8 500k; R5 47k. try that input configuration. Great design. I love point to point.
| Headwize 6N1P OTL headphone amp having hum | mr_push_pull | Tubes / Valves | 39 | 4th July 2011 08:43 AM |
| Aikido 9pin with 6n1p and 6n6p as Headphone | eeyore | Tubes / Valves | 7 | 8th November 2010 01:49 PM |
| FS: Indeed 6N1P headphone amp | Bengali | Swap Meet | 0 | 4th November 2010 05:24 PM |
| Sub 6n6p for 6n1p? | toufu | Tubes / Valves | 3 | 22nd April 2010 04:43 AM |
| Need a little help with Aikido 6n1p/6n6p | S.Spielbergo | Tubes / Valves | 3 | 17th June 2009 02:09 AM |
| Page generated in 0.08864 seconds (73.27% PHP - 26.73% MySQL) with 11 queries |
