Old 14th February 2011, 04:37 AM   #31
h00hbt's Avatar
Originally Posted by Sheldon View Post
BTW are you measuring the unloaded power supply, or with the complete amp?
Sheldon
im measuring loaded.....
Cheers
/H
Old 14th February 2011, 05:14 AM   #32
Sheldon is offline Sheldon  United States
Here's a screen grab from PSUD. I don't know the inductor resistance, so just a guess there. I put in 370V at a rated 150mA for the transformer (it would be double that for your actual transformer, because you are running two channels.) I set it up as a full wave rectifier, to reflect the impedence of the rectifier. It will be slightly different for a bridge, but it will get you close. Voltage is taken at the first Current tap.
Old 14th February 2011, 10:47 AM   #33
richwalters's Avatar
If you have Morgan Jones Valve amps 4th ed, page 360 HT rectifier..shows a 317 job, I don't like using this chip or elevated B+ but the idea of configurating a HV power mosfet for 2nd post regulation (as cap multiplier)to drop the excess may be an idea. Obviously SS gate protection has to be engineered into any arrangement.
There are SS methods of regulating the neg return, but that creates more complications and may not be justifyable.
richy
Old 14th February 2011, 05:30 PM   #34
h00hbt's Avatar
Hi all
Great news! I have succeeded lowering the B+. I changed the 2 first 47uf/500V caps to 2 10uf/630V Polys. Now I have 465V/445V/335V so im smack on what I wanted. Listening to the amp now and it sounds great. I hope I finally can put the building part of this project behind me now and start to enjoy the amp for music.
Thank you all for your input and help and I promise I will be back with more tricky questions for my next project.
Cheers
/H
Old 14th February 2011, 05:34 PM   #35
h00hbt's Avatar
Thanks Sheldon, you where right and your PSUD simulations where spot on, se my latest post.
Take care......
/H
Old 14th February 2011, 06:07 PM   #36
работник
Rod Coleman's Avatar
I bet it sounds improved, too, if you found some good quality MKPs to put in there, in place of those Electrolytics.
Old 14th February 2011, 06:16 PM   #37
Nice looking project. Enjoy.
Sheldon
Old 14th February 2011, 06:32 PM   #38
h00hbt's Avatar
Yes I believe it does. Im thinkung that I maybe will change the double 47uf cap for a pair of 47uf Polys. Tricky thing is what to do with the 500uf.....
Anyway, I will give myself a rest for the time beeing.
Cheers
/H
Old 14th February 2011, 08:11 PM   #39
Might I suggest PSUD?
Old 14th February 2011, 08:12 PM   #40
h00hbt's Avatar
/H
Lowering B+ voltage blue lander Tubelab 39 18th May 2013 01:42 PM
PC for a source. Help lowering PS noise. HaLo6 Digital Line Level 22 12th February 2009 02:58 AM
lowering Qts MCPete Multi-Way 4 31st December 2008 11:09 PM
Lowering HT waner Tubes / Valves 7 29th May 2006 10:31 AM
lowering the voltage Lowjacker Power Supplies 7 11th March 2006 09:11 AM
Copyright ©1999-2013 diyAudio
