diyAudio Sponsor
Old 13th February 2011, 08:58 AM   #1
Default Rectifier tube blows
Hi!
Im quite new to troubleshooting of amps (though know the dangers and how to deload capacitors) and would need some help if I could solve the problem myself (and maybe learn something new!)
I have Yamamoto a08s and the rectifier tube had some electric lightning inside. At that time I didn't know much about these electronics, just thought that the tube needed to be changed. I remember to checked that the ampere meter at the deck showed 0. Every one of the tubes were glowing normally.
After changing the tube the electric lightnings started again. I opened the chassis and saw the diodes blowen (check the drawing). After changing the diodes they soon blowed again - and now it's time to think before doing anything else..
I measured every resistor and they seem to be fine. Also all the capacitors seem to increase their resistance as should when measured with a basic voltage meter. The rectifier tubes filament voltage is about 5.2V and the other pins measure 350V.
I would really appreciate if someone gave me tips what to measure/try to change next (and sorry for my bad English!)
Old 13th February 2011, 09:57 AM   #2
What's the capacitance of the first cap after the rectifier? If it's too large, the PS might be drawing too much current thru the rectifier, thus blowing it. Especially since you seem to be operating at the max rated voltage of the 80.
Old 13th February 2011, 01:22 PM   #3
Banned
It could also be a faulty 717A or 45 Valve or Output Transformer.
I would tentatively suggest trying removing the two non-rectifier valves one at a time to see if the arcing stops, however, the unloaded B+ could exceed the ratring of the caps under no load.
The caps seem well specced, so it may be OK.
Old 13th February 2011, 01:26 PM   #4
Banned
Is it easy to check that the windings of the mains Transformer are all electrically isolated from each other. If you have a current path from HT to one of the heaters, the heaters will act as anodes. This may explain why the diodes have failed.
Old 13th February 2011, 03:51 PM   #5
I removed the 45 tubes one at a time and no arching was seen - but this time the right channel's 717A tube was immediately glowing much much more than the other so I had to pull the power off soon since I had no idea what would happen. I checked that it happens with any 717A in that same channel.
With all the other tubes than the rectifier, both 717A's shine equally. The ampere meter at the deck shows 0 at all times.
Old 13th February 2011, 03:54 PM   #6
Another stupid question from me, but can those caps change their values so that it could be the reason for this prob? The next cap after the rectifier is 5uF (now corrected).
Old 13th February 2011, 03:59 PM   #7
SY's Avatar
Originally Posted by tovaskai View Post
Another stupid question from me, but can those caps change their values so that it could be the reason for this prob? The next cap after the rectifier is 100uF.
WAY too large!!! For this type of tube, that cap should be more like 5-10uF, otherwise death of the tube will occur, sometimes rapidly, sometimes after a bit of use.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 13th February 2011, 04:16 PM   #8
Originally Posted by SY View Post
WAY too large!!!
Omg, sorry my mistake, the first _after_ the choke is 100uF, before is 5uF.. All the caps are original.
Old 13th February 2011, 04:20 PM   #9
SY's Avatar
Whew!
Old 13th February 2011, 04:40 PM   #10
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
tovaskai,
Which diodes are you refering to?
The heater diodes or the Zeners on the 717a?
M. Gregg
What is the sound of one hand clapping?
converting tube rectifier to solid state rectifier. tubo Tubes / Valves 26 24th December 2009 12:12 AM
Tube glows red hot, blows fuse damagefactor Tubes / Valves 17 24th February 2008 07:42 PM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
Tube rectifier for VDIGC tube psu ebijma Chip Amps 2 11th March 2004 04:02 PM
Tube rectifier ?s Tim Wyatt Tubes / Valves 16 10th March 2004 07:03 AM
Page generated in 0.10902 seconds (81.01% PHP - 18.99% MySQL) with 10 queries
