| diyAudio Sponsor | ||
Hi all
Ok, so my newly built PP KT88 Bill amp is working fine now and Im most impressed with the sound. Thanks to all who helped me with the troubleshooting. Now I have some iron left over like PTX and OPTīs and I was thinking that maybe I would use the same schematic as for the KT88īs but adapt it for EL34 tubes. I understand I have to lower the anodedissipation but how do I do it? ![]() ![]() Cheers
/H |
#2 |
Why not a bit more adventurous and try a different design ?
#3 |
Hi Jaap
Well I did ask around for some advice for an integrated stereo PP amp schematic but there wasnīt anything that ticked all the boxes. I would like to use EL34 tubes as output tubes and I have transformers, no chokes. Anyway, what would you suggest? Cheers
/H |
#4 |
diyAudio Moderator Emeritus
Or maybe something even less adventurous.
Like an OddBlock. Except in lieu of the LM317T a cascaded DN2450. Or more adventurous the PP2C by Allen Wright. |
#5 | |
#6 |
/H |
#7 | |
The engineers amp of Pete Millett has a lot of documentation on this forum. It uses 4 dollar output tubes and I expect it to be better than the Bill too. |
#8 | |
Well I would like to do without PCB and too many caps so I think Peteīs amp is out of the question, thanks anyway. Seams hard to find an integrated amp schematic that could work. Cheers
/H |
#9 | |
too many caps ? I don't get that. Finding schematics for PP amps that work is rather easy, google is your friend. You can also look voor KT66/88, or 6550 designs. |
#10 | |
The musicangel schematic looks interesting, thanks. I will look closer at it and get back to you. About caps, At first glance of the picture I thought there where many caps but maybe not. Cheers
/H |
| EL34 PP - again !!! | Klaatu | Tubes / Valves | 9 | 15th August 2010 06:59 PM |
| Which do you prefer - EL84 UL PP or EL34 Triode PP - and why? | ray_moth | Tubes / Valves | 4 | 23rd February 2007 12:22 PM |
| El34 PP Vs. El34 PSE | alexmoose | Tubes / Valves | 47 | 6th September 2006 05:44 PM |
| Troubleshooting a PP EL34 | Bas Horneman | Tubes / Valves | 6 | 16th September 2003 12:11 PM |
| Page generated in 0.11233 seconds (76.55% PHP - 23.45% MySQL) with 11 queries |
