| diyAudio Sponsor | ||
I have a schematic for an amp that uses 6sn7 drivers for 4-El34 outputs. The coupling caps between these stages are 1uf Can I reduce this to .22 or perhaps .47 without affecting performance. Thanks for the help. John Dozier
#2 |
#3 |
That can't really be answered without looking at the schematic. Can you link to it?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
A lot could depend on whether there is global NFB, and where the OPT LF rolloff starts. It is easy to create or solve LF stability problems by changing coupling cap values.
Why do you want to reduce them? |
#5 |
High quality caps in 1uf are hard to find and expensive. I cannot link to the schematic as I do not have it on computer and do not have a scanner. I can calculate the cut off of the RC network though if that would be helpful. Thanks
#6 |
There is a 6.8k resistor in series with each coupling cap. This seems to give a cutoff around 20hz. Check my math please! thanks
#7 |
The 6.8k resistors are grid stoppers. They don't affect LF. The relevant resistance for LF is the grid leak (to ground, or the bias supply). Probably in the region 200-500K.
If you reduce the capacitors you might simply get a bit less LF. Or, because of the increased phase shift, you might get an LF peak around 10-20Hz. With digital sources this does little harm. If you listen to LP then you may get cone flapping. Mains voltage variations can also do this. We can't tell you the answer, because it depends on all the other LF poles in the circuit too. |
#8 |
I appreciate all the help. My knowledge of tube theory is limited. Since high quality 1uf are usually limited to 200v, I think I will use 2-,47uf at 600v, bypassed with .1 and .01 600 v. I hope I can fit them in the chassis I have in mind. thanks again
#9 |
0.22uF will generally be ok for a decent LF response, assuming something from 100k upwards has been used for grid stoppers of the power tubes. Bypassing the coupling caps with yet smaller values makes very little sense IMHO, but whatever floats your boat; it's a free world. Expect very little improvement with values higher than .47uF.
#10 |
The grid stopper is 100k. I think perhaps a .47 600v might be a good value. This way I can use a high quality cap, have it fit, and do away with the bypasses. What say You? Thanks again
| no coupling caps | ray bronk | Tubes / Valves | 2 | 20th May 2008 07:10 AM |
| Coupling caps. | Trebla | Class D | 5 | 1st March 2006 09:12 PM |
| coupling caps | el capitan83 | Tubes / Valves | 10 | 17th December 2004 04:25 PM |
| coupling caps??? | AudioGeek | Tubes / Valves | 14 | 16th September 2004 12:05 PM |
| What value for the coupling caps? | roibm | Parts | 12 | 23rd March 2004 05:58 PM |
| Page generated in 0.09435 seconds (79.00% PHP - 21.00% MySQL) with 10 queries |
