diyAudio Sponsor
Old 11th February 2011, 05:38 AM   #1
ditubo is offline ditubo  United States
Default Stepped Attenuator for AI Modulus IIA
What would be the best affordable stepped attenuator to replace the volume pots (continuous type) on an Audible Illusions Modulus IIA and what other mods can I do to it? I will be receiving the preamp any time tomorrow (Friday Feb 11, 2011) and am very excited. I want to hear how it will sound compared to my for mer pre (Counterpoint SA 7.1). Also need to know which value for the pots, 50K or 100K. Thanks in advance.
Is it even worth the time to modify the volume pots?
Old 11th February 2011, 09:45 AM   #2
mastodon's Avatar
Why not just listen to the amp 'as-is' for a while, and then decide if it requires improvement and in which areas?
Old 11th February 2011, 12:34 PM   #3
kstagger's Avatar
Cheap volume pots can suffer from channel imbalance. I've had it happen with "Blue Alps" (note - could be counterfeit knockoffs), I've replaced it with a stepped attenuator and it did sound better. - better balance between channels and a 'smoother' volume grade.
But as mastodon noted, give it a listen before you modify.
Old 11th February 2011, 01:36 PM   #4
DF96 is offline DF96  England
Audible Illusions
What a wonderful name for audio equipment! Are they admitting that it is not what it seems?
I agree with the others. Listen to it before you start fiddling with it. Assuming, that is, that it was bought in order to listen to music rather than as a platform for bragging to friends.
Old 11th February 2011, 05:31 PM   #5
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
My friend from Israel shipped me some ladder attenuators. I can't think about anything better. He made for 10K, 50K, and 600 Ohm. PM me if you want more info.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 28th December 2011, 03:53 PM   #6
nsx51 is offline nsx51  United States
ditubo, I also have a Modulus 11a, and am curious as to what you have done to yours. Did you change the volume pots? Anything else?
Recommended tubes for AI Modulus 3A, C-J MV55 and Moscode 300 infotrad Tubes / Valves 0 3rd July 2007 08:07 PM
stepped attenuator ivegotmono Tubes / Valves 4 7th January 2006 02:49 PM
Stepped attenuator Bas Horneman Tubes / Valves 24 16th June 2004 07:18 AM
Stepped Attenuator officeboy Parts 3 6th May 2004 03:32 PM
Page generated in 0.08563 seconds (73.42% PHP - 26.58% MySQL) with 10 queries
