Grid current and direct coupling
Old 27th July 2003, 10:16 PM   #1
jeff mai is offline jeff mai  Australia
jeff mai's Avatar
Default Grid current and direct coupling
I'm curious to learn about what happens when direct coupled circuits conduct grid current. I've got lots of questions.
Where is the grid current supplied from in a direct coupled stage? Is it supplied from B+ through the anode load of the previous stage?
What is different if the anode load of the preceding stage is a choke? And what if the choke also provides the bias for the following stage like a DRD or Monkey topology?
Thanks in advance!
Jeff
Old 27th July 2003, 10:26 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Jeff,
Must be.
If direct coupled: the same, but the output swing can be above +B due to the reactance, so it'll come from that stored energy.
It should ve the same as if the grid was connected from a driver transformer or grid-choke.
...........I think............
So I think that A2 must be possible with monkey, as long as the source z is low enough - was that the question?
Old 27th July 2003, 10:39 PM   #3
jeff mai's Avatar
Well, it was the question...sort of.
Actually, my main question is this: cathode followers aside, is direct coupling a good idea for intentional A2 operation?
Going back to your statement, what forms the source z for the grid in a monkey configuration?
Also, because the choke in a monkey sets the bias of the output stage, wouldn't you get some sort of feedback if you drove the tube into grid current?
Thanks,
Jeff
Old 28th July 2003, 12:21 AM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
No.
Frank
Old 28th July 2003, 08:00 AM   #5
dhaen's Avatar
Default Hardly a trivial question......
Jeff,
I'm in the area of speculation here, so please indulge me
I think that the source Z of a monkey driver is set mainly by the Rp of the driver. The DC source resistance being the source z in series with the winding resistance. Aha, and the output stages cathode components will affect as well- now I'm beginning to see where you're coming from.
It needs someone to try it, I think.
Frank, you may well be right. Please convince us.....
Old 28th July 2003, 08:56 AM   #6
TG is offline TG  Ukraine
Send a message via ICQ to TG
Hello,
I'd say, capacitor coupling is a bad idea for A2...
Good luck!
Old 28th July 2003, 08:57 AM   #7
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
The thing with a monkey is the grid current will cause the grid voltage to fall, while at the same time the cathode rises due to increased tube current. But the grid current is nullified because whatever goes into the grid comes out of the cathode, so bias depends upon cathode current, which should go up in this situation. Overall I think it would be a pretty stable situation to apply current to. Put some local NFB on the driver to drop its Zo and you should be good to go...
Tim (shouldn't be typing this tired)
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 28th July 2003, 08:59 AM   #8
dhaen's Avatar
Originally posted by TG
Hello,
Good luck!
Hhha
Old 28th July 2003, 09:25 AM   #9
Pjotr is offline Pjotr
Pjotr's Avatar
Maybe this can shed some light on it:
http://melhuish.org/audio/46amp.htm
Some real schematic helps to discuss.
Cheers
Old 28th July 2003, 11:25 AM   #10
jeff mai's Avatar
If the grid voltage falls and the cathode voltage rises, the bias has shifted. Not good! I don't think you'd want any grid current to occur in a monkey or DRD amp because of this.
Let's simplify things by just choke loading and direct coupling the driver stage to the output, using a separate B+ supply. Does grid current do evil things to the driver stage's bias since that grid current must be supplied through the driver's plate choke?
Jeff
Grid current and direct couplingHide this!Advertise here!
ccs, direct coupling and stuff beamnet Tubes / Valves 22 31st January 2006 02:22 PM
transformer coupling, magnetic amplifiers, grid leak current metebalci Tubes / Valves 9 24th March 2004 11:22 AM
direct coupling 2a3maniac Tubes / Valves 9 13th February 2004 09:36 PM
direct coupling 2a3maniac Tubes / Valves 11 2nd February 2004 07:19 PM
Direct coupling question... SHiFTY Tubes / Valves 8 3rd October 2003 09:49 PM
