Microphonics from C0G Caps across Heaters Microphonics from C0G Caps across Heaters - diyAudio
Old 7th February 2011, 02:57 PM   #1
Magz is offline Magz  United States
Default Microphonics from C0G Caps across Heaters
Hello,
I have a sudden issue with microphonics in my tube preamp, and I'm wondering if C0G ceramics are the cause. I added a 0.1uF TDK multilayer radial-leaded C0G across the heater pins at the socket of all the signal tubes in the pre, and it did seem to result in a bit blacker background, so I was happy with them, but I've noticed that if I tap on any part of the preamp chassis, I get a fairly loud thump coming through my speakers. It doesn't seem to be related to any particular tube - they all thump if tapped, as does the chassis - and it was definitely not present before the addition of the caps.
I have read that C0G ceramics are much less prone to microphonics than the other ceramic types, so I'm surprised by this. I plan to take them out or perhaps replace them with film caps, but I have two questions:
1) Has anyone else experienced this problem with C0G caps across heater pins?
2) Might I be better off with two caps per tube (from each side of the heater to ground) than with one cap across the heater pins?
Any help/experience sharing is greatly appreciated.
Here is a link to the exact caps used:
Digi-Key - 445-4756-ND (Manufacturer - FK20C0G1H104J)
Old 7th February 2011, 03:30 PM   #2
db! is offline db!  Canada
You should try removing the caps to see if it makes a difference...
Also, have you subjected the tubes to any shock or impact(drop, hard bump, etc) lately?
From what I understand, tubes can go microphonic if the internal support structures are disturbed/damaged...
Old 7th February 2011, 03:54 PM   #3
I will certainly try removing them, I was just looking to see if this had happened to others with these caps. The reason I don't think it's a tube issue is that ALL of the tubes make the thump when they are tapped, and tapping the chassis anywhere also produces the sound. I didn't notice it until a couple of weeks after I installed the caps, but that's probably because I didn't happen to tap on the chassis during that time.
Old 7th February 2011, 09:23 PM   #4
taj is offline taj  Canada
taj's Avatar
C0G/NP0 ceramic caps are a world better than regular (say, X7R) ceramic caps, and are much less prone to microphonics, but you never know.
Also, because you're using them on the heater, I wouldn't expect microphonics to be an issue there, but you never know (at least I never know.).
..Todd
Old 7th February 2011, 09:32 PM   #5
On Hiatus
SY's Avatar
Since this happened right after you did a bunch of soldering at tube sockets, my suspicions would be on that.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 7th February 2011, 09:40 PM   #6
jcx is offline jcx  United States
I would guess a sensitive (and high potential) wire may be in a different location, possilby closer to the chassis gnd than before
or (seems unlikely) the cantilever mass of the added caps at the sockets are mechanically coupling the thumps into the tubes better
electrically the caps seem hard to explain as a source of microphonics
Old 7th February 2011, 11:02 PM   #7
tomchr is offline tomchr  Canada
tomchr's Avatar
Some ceramic capacitor dielectrics are piezoelectric. But I doubt that's the case for C0G or NP0 types of dielectric. In any event, the force you're applying to the caps while thumping the chassis is minuscule and if any voltage was induced on the cap through microphonics it would have to couple through the heater to the active elements in the tube. I just don't see that as a plausible explanation.
I'd look for cold solder joints and the like.
~Tom
Old 8th February 2011, 12:51 AM   #8
Thanks for the replies. So it seems that the caps are a longshot as the problem source. I'll need to open it up to remove/change the caps anyway, so I'll do a thorough sweep through and see what I can find. Maybe I'll swap in some new tubes before that just to see if I have a badly microphonic one as well.
Any advice on whether it is preferable to put one cap across the heater pins or two caps, one from each pin to ground?
Old 8th February 2011, 12:57 AM   #9
On Hiatus
SY's Avatar
The latter, for sure.
Old 8th February 2011, 01:24 AM   #10
Thanks, Sy. When I go in there to poke around I'll set it up with two caps per tube.
Thanks to all who answered! It'll be a week or so until I can go in there and check it out since I need to order more caps, but I'll post what I find then.
Microphonics from C0G Caps across HeatersHide this!Advertise here!
C0G/NP0 as coupling caps? Salas Parts 8 13th June 2010 09:31 PM
Microphonics? Carlp Tubes / Valves 5 28th August 2008 12:19 AM
C0G/NP0 Ceramics in Active Filter Circuits speakerguy79 Solid State 8 19th July 2008 09:39 AM
Why not NP0/C0G caps? gmikol Parts 23 12th March 2008 06:10 AM
X7R vs NP0/C0G Ceramic Caps speakerguy79 Parts 4 6th March 2007 11:52 PM
Copyright 1999-2017 diyAudio
