Tubed voltage regulator for KT88se amp, need help ?
Old 7th February 2011, 04:26 AM   #1
jmillerdoc is offline jmillerdoc  United States
jmillerdoc's Avatar
Default Tubed voltage regulator for KT88se amp, need help ?
Hello,
Last year I built this amp:
stereo SE kt88 build ... abdellah diyaudioprojects design
It has been one of my favorites. I have all the parts to build another one but this time I would like to add a regulated (tube) power supply. I have never used regulated supplies on any of my previous builds but have heard praises sang about the benefits of regulated supplies.
I was hoping someone might have a fairly simple, easy to construct design that I could implement in place of the unregulated supply for this design.
I want to use all tubes as I have a lot of real-estate on my chassis.
Thanks for your help in advance.
Jeff
Old 7th February 2011, 06:52 AM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
steve bench's series of articles on tubed regulators, although you've probably been there already...
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 7th February 2011, 07:46 AM   #3
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
The TCJ issue archives from may 1999 to august 1999 at John Broskie's Guide to Tube Circuit Analysis & Design
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 7th February 2011, 12:51 PM   #4
jmillerdoc's Avatar
Ok,
Thanks for the great links. I have read all the info there, I think I have a good understanding of how these different topologies work. Problem is I don't think I am savvy enough to create my own design "de novo". What I am really asking for is a "drop in" regulator circuit/schematic with all the component values figured out for the amp at hand.
Second best would be a schematic close enough that has adjustable features I could "dial in" the proper voltage. Can anyone supply me with a schematic I could use like this on this amp? I already have an identical amp built without the regulated supply. I could build the circuit on a proto board and splice it into my existing amp for test and tweak purposes. Once refined I could build another amp with this circuit installed.
Jeff
Tubed voltage regulator for KT88se amp, need help ?Hide this!Advertise here!
The Voltage-Regulator-Chip Amp family welcomes a new member: Elvee Chip Amps 9 14th November 2010 08:52 AM
Off board MOSFET's & CCS voltage regulator zebra100 Solid State 6 21st July 2010 01:27 AM
Mikaels KT88SE & VTV Octal Linestage AKlein Tubes / Valves 17 10th June 2008 03:16 AM
tube voltage regulator error amp nhuwar Tubes / Valves 14 20th May 2008 10:38 PM
