From KT90 to KT88
From KT90 to KT88
Old 14th February 2011, 08:12 PM   #21
kevinkr's Avatar
From KT90 to KT88
Originally Posted by ManUtd View Post
Will i be able to measure Bias voltage across cathode resistor 10R/5W ?
This voltage should be around 1V for KT88 meaning 100mA Bias current?
I mean by doing this i avoid from measuring directly on High Voltages (Do`nt like)
I don't know what your plate voltage is but if it is anything over 400V, 100mA of plate current is going to melt most current production KT88 before your very eyes.
I would recommend something like 75mA up to about 450V, and somewhat lower at 500V for best longevity.
Yes you can measure the bias across a resistor in the cathode circuit, this of course is combined plate and screen grid current which is fine, and will give you an accurate picture of the combined plate and screen dissipation as long as you know the plate voltage.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th February 2011, 08:21 PM   #22
ManUtd is offline ManUtd  Norway
ManUtd's Avatar
Thanks for Your reply,
So 75mA means i will measure 750mV across my 10R/5W resistor on Pin 8 (Cathode).I could then adjust V1 and V2 accordingly?
I forgot to mention that i am using scematic i posted earlier in my post.
Old 14th February 2011, 08:38 PM   #23
kevinkr's Avatar
From KT90 to KT88
I'm assuming that your plate supply is somewhat over 500V so I would say that 70mA would be safer for use with KT88 at these voltages. You will measure 700mV across the 10R/5W resistor in the cathode circuit of each tube, and yes you would adjust V1 and V2 accordingly.
I should have realized that it was that earlier schematic, but I neglected to go back and look.
One other thing is that not all KT88 are created equal, and some will safely dissipate more than others despite what the specification sheets say. I have had trouble with ones from just about any maker you can think of. Observe very closely for the first hundred hours or so that they are not developing red spots on the plate.
The Genelex reissues are supposedly amongst the best sounding and most rugged of these types. I've had my share of problems with both JJ and EH branded KT88. I have not tried the Svetlana SPb manufactured KT88, but have heard from reputable sources that it is not the best sounding choice. IMLE the JJ KT88 sounds very good and may be reliable if you get ones that have been sorted, matched and burned in. I have no experience at all with current Shuguang production. As always YMMV...
Old 14th February 2011, 09:08 PM   #24
ManUtd's Avatar
Thanks again for Your Quick Reply.
I got some matched "C" tubes(2 matched pairs) i want to try instead of KT90 EH.What is Your suggest about the 220K grid resistor they talked about earlier in this post? Is it more safe to change it to a 100k res when using
KT88 or can i keep it with 220k.
Old 14th February 2011, 09:38 PM   #25
kevinkr's Avatar
From KT90 to KT88
I would reduce the value of the 220K resistors to 100K if possible or as close as you can get to it without compromising the sound of your amplifier. I've used 150K resistors without issue, but I wouldn't go any higher than this, and 100K are preferable. YMMV..
Old 15th February 2011, 07:19 AM   #26
richwalters is offline richwalters
richwalters's Avatar
I believe your amp runs at 500V ???.......at 100mA bias for KT88's is dangerously high, the tubes will be glowin' orange .....enough to grill a chicken. Increase neg bias volts to give around 50-60mA per tube and no higher. Once you set the quiescent current, multiply that by the anode voltage and one roughly gets the tube dissipation. 30-40W for new build KT88's is enough otherwise they will have a very short life.
V/R=I ...Ohms law. You know what R is..It's as simple as that.
richy
Old 15th February 2011, 07:27 AM   #27
Funny, I was using one as the pass element in the power supply to my phono stage, running at 70mA with 250V across it it lasted barely two years. Needless to say I won't buy any more, in fact I am now running a vintage GE 6550A in that socket.. The reissue died somewhat noisily (lots of gain in the stages it powered) no evidence of electrical damage, but it developed an internal rattle which makes me think that some weld somewhere failed..
I've gotton back to New Sensor on similiar issues......I may never get a reply but will inform if and when something comes through.
A pic enclosed of some N Edit 6550 short life grey looking sick getters. IMO not worth paying for. The question is what to do with all those (100's) in my MI amps. A car-like recall ?
richy
Old 15th February 2011, 12:16 PM   #28
kevinkr's Avatar
From KT90 to KT88
richy
Looks like they weren't pumped down all that well during production and perhaps the plates and other elements out gassed during operation? I've seen vintage ones that looked like this at about 10K hours of operation...
Old 15th February 2011, 12:38 PM   #29
GTHICM is offline GTHICM  United States
Send a message via AIM to GTHICM From KT90 to KT88
Default EH KT88 Firebottles
Your experience is the same as mine, Kevin. I am running some ASL Hurricanes so need 16 power tubes. A good many of the EH KT-88s I bought went into runaway mode and I caught all of them, save one, which blasted out resistors and the tube socket as well! I am always checking the bias so as to catch any more runaways before any real damage is done. I have heard that the latest Shuguangs sound good and are reliable. Not sure but at least hope it will be some time before I have to retube. It gets a little pricey with 16 tubes needed!
Old 16th February 2011, 07:48 PM   #30
ManUtd's Avatar
Here is scematic with KT90.
Is it 33k at V1 and V2 ? for Bias adjustment?
What will readings be with KT88 ?
What is the watt tolerance for Grid resistor (220K) for this specific amplifier
according to this scematic?
I have at hand 150K 2Watt. Will they be fine?
From KT90 to KT88Hide this!Advertise here!
MA XDSE KT88 vs YAQIN MC-100B KT88 esangenisd Tubes / Valves 3 23rd May 2010 11:38 AM
FS: Ei/Yugo KT90 quad, 6H30, svet KT88 quad - melbourne avian Swap Meet 9 15th April 2010 06:46 PM
KT90 why this ? richwalters Tubes / Valves 8 19th February 2008 01:42 PM
Replacing KT88 with KT90 - Beginner's questions horace Tubes / Valves 25 3rd November 2007 07:48 AM
KT88 vs. KT90 bench test richwalters Tubes / Valves 4 23rd December 2004 11:19 AM
