diyAudio Sponsor
Old 2nd February 2011, 03:23 AM   #1
Dagwood is offline Dagwood  New Zealand
Dagwood's Avatar
Default Any ideas on this one???
Hi all,
I've searched the web for over an hour and cannot find any details on this valve
Print reads,
STC
290
4013
AUG - 60
Any ideas???
If you keep digging in the garden of failure you will eventually find success
Old 2nd February 2011, 03:31 AM   #2
HollowState's Avatar
It isn't a tube. It's a crystal and it looks like it might be bad. the connection looks broken off. Maybe just the picture?
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 2nd February 2011, 03:38 AM   #3
Dagwood's Avatar
Thanks for that any more info ???
Seems tobe intact to me, have attached another pic
Old 2nd February 2011, 03:44 AM   #4
Ok, now it looks better. Probably quartz. No telling what the frequency is by those numbers though. By the thickness of it I'd guess it was fairly low. Maybe 100K or so. (?) You'd have to hook it up with something like a one transistor Pierce oscillator and measure the frequency.
Old 2nd February 2011, 03:59 AM   #5
Dagwood's Avatar
Thanks Hollowstate
Will put that one away for a rainy day.
Thanks again.
Old 2nd February 2011, 04:14 AM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Most probably it is not quartz, it is a salt crystal resonator, that's why it is in sealed envelope. But may be it is a quartz. 290 KHz?
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 2nd February 2011, 04:35 AM   #7
And you have to ask yourself how did the guy get his hand in there to write the "699" on the mica?
Gary
Old 2nd February 2011, 06:07 PM   #8
tomchr is offline tomchr  United States
tomchr's Avatar
One thing I've come to appreciate about tubes is that you can tell the pinout by looking through the glass at the internal connections...
I'd run an impedance sweep. Ground one side of the XTAL and hook up the other side through a resistor (10 kOhm would be my starting point) to a function generator. Then measure the voltage across the XTAL as you sweep the frequency. You should hit minimum voltage at the series resonance and maximum voltage at the parallel resonance.
~Tom
Looking for ideas coldcathode Tubes / Valves 12 12th August 2009 02:08 PM
Need Ideas Arc Multi-Way 0 10th March 2007 01:45 AM
Just some ideas.. Ultima Thule Solid State 0 3rd October 2005 11:41 PM
2 New ideas, what do you think? lumanauw Solid State 4 6th April 2005 09:04 AM
Ideas please... kspv Digital Source 1 3rd July 2004 07:07 AM
Page generated in 0.14875 seconds (55.07% PHP - 44.93% MySQL) with 11 queries
