| diyAudio Sponsor | ||
Ok so i got my hands on a few russians:
-4x 6p14p -1x 6n6p -1x 6n2p-ev I'm new to this field. I do not have much experience with electronics so i will need some help. First step is obvious....chosing a schematic: Right now i have my eye on this schematic( triode/pentode operating mode) ![]() I welcome any sugestion about this schematic or other schematics. |
#2 |
I linked someone to that schematic a couple of weeks ago, and it wasn't greeted with much enthusiasm by the regulars on this forum. The schematic is most likely a guitar amp offering high gain...and high distortion.
Alternatives that are much better sounding (apparently; I haven't built either) can be found here: Simple EL84 poweramp/integrated (push pull, which is no problem since you have 4 6p14p's) http://www.decware.com/se84cschematic.pdf (single ended triode mode; less power, more expensive output transformer, but I'd prefer to build this one myself) |
#3 |
Well i can get a ton more 6p14p's...but i'm gonna stick to a SE for the moment. PP will be my next project
I will read more about the zen project. Look at this one also. It's made by a guy from my country...and it seems that he knows a few thing about tube amps :P....but looks hard to build... |
#4 |
That should work as well, but you'll have to find the appropriate OPT with the feedback taps. I guess they're not too common these days, but I'm not sure.
#5 |
I'm gonna build them anyway :P. Me ....or someone with a little more experience
I can get a pair of simpel ot's for ~ 40E or less |
#6 |
If you use the 'Valderama' circuit shown above, you will need to add feedback from the secondary side of the OPT. Hence, the circuit will require some modification. I'd personally stick to the tried and tested decware amp. You could modify it to use the 6n6p.
Sounds like a good deal on the transformers, you got any specs of those? |
#7 |
well the ot will be custom made anyway. maybe i can have them done by the same guy ho made the schematic :P.
do you know what power rating can i get from the decware schematic ? I love the fact that it is so simple.... |
#8 | |
The decware SE will put out about 2W max, which is enough for efficient bookshelf speakers. For comparison: I'm currently using a badly designed 2x6AQ5 PP triode amp in my living room that will put out no more than about 750mW, which is enough to reach quite neighbor-unfriendly sound levels
#9 |
any other opinions about valderama's schematic here ?
#10 |
I noticed this thread and thought I would add a little about the Decware Zen Amp. We purchased a DIY Zkit1 amp and found it very easy to build. It is like the SE84 link shown on this site. It only has the two SV83 tubes and one 6n1p tube. It has produced 2.3w/channel at full volume. We are using it for an amp to test speakers built due to it's small size. When testing the desktop speakers, which are 90dB @ 1/W, we realized how much 2watts/channel can be. We will have it turned up to 12 o'clock on the volume dial and it's loud enough to wake the wife without giving out. This kit is bridgeable (5w/channel) and can be modified for use with a rectifier tube like in the SE84C. The ot's do not have specs on them but they are custom made for Decware.
This amp has been solid by far with many hours put on it. One nice part about the amp for testing is the load can very from 2ohms to 8ohms. With all of that said, this is a fun little DIY project anyone can do. Even if you haven't slung solder before. It's $300 and comes with the power transformer, two output transformers and the PC board with parts, volume knob, input connections, mounting screws, and binding posts. A solid purchase. http://www.decware.com/newsite/SE84CDIY.pdf |
| 6n6p or 6P14P-ev for driver | nightanole | Tubes / Valves | 11 | 30th August 2010 03:07 PM |
| El 84 / 6p14p Se Opt Transformers | Dj Dog | Swap Meet | 3 | 31st August 2008 04:29 PM |
| 5W EL84 drive EL84 SE | Audio_idiot | Tubes / Valves | 30 | 19th November 2007 04:44 AM |
| 6P14P Amp Scratch Build | sorenj07 | Tubes / Valves | 41 | 9th January 2007 11:26 PM |
| Page generated in 0.11037 seconds (78.50% PHP - 21.50% MySQL) with 11 queries |
