diyAudio Sponsor
Old 15th October 2011, 01:28 PM   #71
pmillett's Avatar
Originally Posted by Calku View Post
220uf 450V cap Panasonic EET-UQ2W221DA under Mfg PN will not fit FPE Case. It's 30mm.
You are correct, it should end in "KF" not "DA", like the Mouser part number (which is correct). Sorry about that...
Pete
When life hands you a jeffery, stroke the furry wall.
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
DIY "Teleportation Tweak" & "CLC"? GlidingDutchman Everything Else 12 12th June 2009 10:40 PM
PCB cerrection for "Red Circuits Mosfet design" please! BlacK_Chicken Solid State 5 21st September 2007 09:11 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Page generated in 0.06284 seconds (63.15% PHP - 36.85% MySQL) with 10 queries
