"Jonokuchi" - new desktop amp, or "Little red board"? - Page 4 - diyAudio
Old 4th April 2011, 04:19 PM   #31
Hi all,
I am getting ready to populate my board. While laying all the parts out, I realized that I had forgotten to order D2-5. Can I use anything else? Say 1n4007's or something else that the shack might have?
Tia,
Al
Old 4th April 2011, 04:56 PM   #32
I have 1n4007's. Or should I just order and wait?
Old 4th April 2011, 06:20 PM   #33
I also have an 8h choke 150ohm 125ma that I would like to use instead of r5. Is there an easy way to drop the b+ back where it needs to be?
Old 4th April 2011, 06:45 PM   #34
pmillett's Avatar
1N4007 will work fine. It might induce some noise... if you hear a buzz, replace them with SiC rectifiers.
You might not need to do anything - if it's 150 ohms you will be pretty close. Try it!
Pete
Old 4th April 2011, 06:57 PM   #35
Thanks. How shall I orient the diodes? Stupid question I think I know the answer to, just want to verify.
Tia
Al
Old 4th April 2011, 07:04 PM   #36
Ty_Bower's Avatar
Might the choke also help stifle some of the noise he could get from the slow 1N4007 diodes?
Old 4th April 2011, 08:34 PM   #37
The choke that I am using is the cheap Rcd-100 from Radiodaze. Custom When I purchased them, they were $8.95. Now they are a whopping $10.95. I think they are a pretty good value.
Old 4th April 2011, 08:39 PM   #38
pmillett's Avatar
Tia
Al
Not such a stupid question! The left terminal of the TO-220 diode as you look at it from the front is the cathode. There's also a tiny dot on the PCB silkscreen next to the cathode lead.
Old 4th April 2011, 08:42 PM   #39
pmillett's Avatar
It might, though sometimes diode recovery noise gets around by capacitive or magnetic coupling... if that happens the only way to get rid of it is to spread things out, or remove it at the source. Quite often it couples across the power transformer to the filament winding, then capacitively to the cathodes...
Old 4th April 2011, 08:42 PM   #40
So dot= -, right
Al
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
DIY "Teleportation Tweak" & "CLC"? GlidingDutchman Everything Else 12 12th June 2009 10:40 PM
PCB cerrection for "Red Circuits Mosfet design" please! BlacK_Chicken Solid State 5 21st September 2007 09:11 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright ©1999-2017 diyAudio
