"Jonokuchi" - new desktop amp, or "Little red board"?
Old 4th April 2011, 08:49 PM   #41
apurcell22 is offline apurcell22  United States
Guess I will use what I have on hand for testing, then order the ones from the bom to swap out when they get here. I plan to shoot pix of the process, and post them on audiokarma.org. This was a request from a member there. Pete, you are welcome to use any of it for a manual if it helps. I will update with a link when I post it.
Again many thanks to your contributions to the Diy community,
Al Purcell
Old 12th April 2011, 09:37 PM   #42
imnewbie is offline imnewbie  United States
How big of an improvement the $12 Radiodaze choke (or any similar Hammond or Triad choke) can make in this particular amp compared to the resistor? I have collected all the parts same as on the BOM. Yes, I understand a choke will sound better any how, but will this particular amp benefit greatly or just marginally from a choke?
Now the question about chassis..
Are the headphone jacks and potentiometer grounded on PCB? I'm thinking about using aluminum top plate bolted on a frame of wood, drilling the holes for headphone jacks and potentiometer on the front piece of wood. Speaker posts, RCA and IEC all will be mounted on the top aluminum plate. So, is it safe to use wooden front panel or the headphone jacks and pot must be grounded on a metal chassis like Hammond?
Old 13th April 2011, 08:21 PM   #43
pmillett is offline pmillett  United States
pmillett's Avatar
The jacks are grounded on the PCB, and are actually insulated from the panel. So no problems there. The pot mechanicals (shaft, front) are not grounded to the PCB. You may or may not need to somehow ground this. Sometimes if you leave it ungrounded, especially with a metal knob, you will hear hum/noise when you bring your hand near the volume knob.
Pete
Old 25th April 2011, 05:46 PM   #44
What is JP1? Is it needed? It's not on the BOM
Old 25th April 2011, 06:37 PM   #45
pmillett's Avatar
Just a way to defeat the ground loop breaker and connect signal ground directly to AC ground. You probably will not need it.
Pete
Old 25th April 2011, 06:51 PM   #46
Thanks Pete. I should have this up and running today.
Al
Old 26th April 2011, 11:26 PM   #47
Pete
Just noticed that the board seems to be opposite what the conventional setup should be. Looks like you just swapped the inputs to the board. Is this correct?
Old 27th April 2011, 01:37 AM   #48
I completed the amp this afternoon. It sounds nice, except for the hum. I thought that this thing would be dead quiet with the added choke. I haven't taken any voltage readings yet, nor have I lifted the ground to see if that quieted things down. You can't hear it when the music is playing, only in quiet passages, but I am sure it will sound even better when the hum is gone.
Al
Old 27th April 2011, 03:11 AM   #49
Ok. Lifting the ground nor switching polarity made much of a difference. It made a little, but once I moved the volume pot a little, there it was.
Old 27th April 2011, 02:56 PM   #50
pmillett's Avatar
Is the hum still there when the pot is all the way down? If so, how far are the OPTs away from the power transformer and choke(s)?
"Jonokuchi" - new desktop amp, or "Little red board"?Hide this!Advertise here!
"TECHNO"Amp building in progress-using "Iron Method" zox2003 Solid State 23 30th March 2010 08:42 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
DIY "Teleportation Tweak" & "CLC"? GlidingDutchman Everything Else 12 12th June 2009 10:40 PM
PCB cerrection for "Red Circuits Mosfet design" please! BlacK_Chicken Solid State 5 21st September 2007 09:11 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Copyright ©1999-2017 diyAudio
