| diyAudio Sponsor | ||
Hello
Did someone do Tube Pre Amplifier with Tone Control Schematic Diagram Adrian Angka Weblog Is this working good? I'm looking for some tone control (tube or very good silicon one) for my DIY tube amplifier (PP 4 x EL34). It sound so perfect that for most of CDs it's not needed But sometimes it's needed .
#2 |
Really good tone controls are not particularly simple. The attached Max Robinson design is "unity" gain. However, 4X 12AX7s just for stereo tone controls is (IMO) OTT. You can simply the signal path and reduce the bottle count by replacing the cap. coupled cathode followers with DC coupled ZVN0545A source followers.
Eli D. |
#3 |
WHat do you think about silocone tone control for tube amplifier? Step by step there is lower and lower space for another things. Could you suggest some very good diagram (PCB is welcome).
#4 |
Have a look through this thread - a lot to learn and a proposal for tone controls you may like. No pcb though.
Aspen Headphone Amp
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#5 |
Looks like everything you need is available here:
The James-Baxandall Passive Tone-Control Network ~Tom |
| Looking for Very good tone control schem. | vytas | Solid State | 27 | 22nd March 2012 12:25 PM |
| Tone control | argonrepublic | Solid State | 11 | 13th November 2011 01:32 AM |
| Tone control | argonrepublic | Solid State | 0 | 28th February 2010 12:12 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Accuphase Tone Control Needed | robinson_guitar | Solid State | 0 | 10th January 2007 06:27 AM |
| Page generated in 0.08837 seconds (70.64% PHP - 29.36% MySQL) with 11 queries |
