| diyAudio Sponsor | ||
I found this Pentron MM4 microphone mixer and would like to try using it for recording. It has 4 channels each going through one section of a 12ax7. I thought I would try the circuit as is and then simply wire 2 channels with cascading gain each through 2 sections of 12ax7 with 2 outputs instead of 1.
I dont have much experience with this but understand some basics. I have not tested it yet. I will definitely replace the power cord with a 3 prong and most likely the filter and cathode bias caps. should the selenium rectifier be replaced? How do you do that without changing the B+ voltage? Any ideas or suggestions are welcome thanks for your help mm4.jpg |
#2 |
Selenium rectifiers are problem areas. I would at least see if it's okay but know that you'll eventually have to replace it. While it's still working, measure the B+. Replace it with a silicon diode (1N4007) and series resistor, which you adjust to restore the proper B+. In fact, set it for about 5% low because of the slow increase of power line voltage over the years.
#3 |
This mixer uses high impedance mixing and should therefore only be fed into something with a high input impedance - 500K or more to be safe.
Replace the selenium rectifier. The increase in HT voltage will not materially affect the circuit operation in this case. Cheers Ian
Ian |
#4 |
The diode gets matched up with striped side same side where + would be on the selenium rectifier?
I'll be plugging the output of the mixer into my Presonus firebox which has 2 xlr balanced (1300ohm) preamp ins, 2 instrument (1M) preamp ins and 2 balanced line ins (10k). So I'll use the instrument ins, correct? If say I wanted to make a 2 channel preamp out of this, one side being XLR microphone and the other being a tube DI maybe I would want to put a transformer on the XLR side so I could plug a SM57 into it or even add phantom power...what would be a cheap but decent transformer to add? I don't want to go too crazy with this project but a 1 channel mic pre and tube DI for bass would be really cool and useful for home recording projects... |
#5 |
100K pots loaded on 300K resistors, it is fine for them. If you load 330K on zero ohm you can get theoretically best summing: less dependence between channels, trade off: less gain.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#6 |
Transformers, well cheap and decent don't generally coexist.
It's common to use a high input impedance regardless of source. However, low source impedance means small voltages and consequent low output with more noise. A cheaper way is to make an amplifier rather than use a transformer. And yes that's the correct direction for the diode. I think the output of your new preamplifier will be too much for the instrument input of the power amplifier. Best to use one of the balanced line inputs; you can safely ground one side of the balanced input. |
#7 |
I'd agree with replacing the caps and the rectifier, but would probably use a better diode than a 1N4007. A BYV26E fast recovery diode will set you back a whole nineteen cents at Newark.
Don't electrocute yourself. Jim |
#8 | |
Brgds Lars |
#9 |
If you make this for stereo I would split the cathode connections to one 4.8k resistor for each section bypassed with a 25 mfd cap. That is 1200 ohms times 4 , for 4 tubes to maintain the same bias and reduce crosstalk between channels.
Replace the selenium rectifier too. Hope this helps Ed |
#10 |
Thanks that seems like a good idea. Why is that a good idea exactly? does it just help to keep each section properly biased?
If I cascade the gain stages can I just take from right after the 330k resistor following gain control right into the grid of the second stage? |
| DIY tube microphone preamp | Thebrain | Tubes / Valves | 16 | 28th February 2012 05:04 PM |
| Posted tube microphone preamp design | pmillett | Tubes / Valves | 11 | 30th July 2011 06:36 PM |
| tube microphone preamp design ideas | PRNDL | Tubes / Valves | 9 | 7th June 2008 05:43 PM |
| mono tube microphone preamp | betavision | Tubes / Valves | 0 | 5th February 2006 08:44 AM |
| Tube mic preamp/mixer | Sir Trefor | Tubes / Valves | 31 | 21st November 2004 09:52 PM |
| Page generated in 0.12615 seconds (79.26% PHP - 20.74% MySQL) with 11 queries |
