1Gohm or higher resistor ... - Page 3 - diyAudio
Old 30th January 2011, 09:50 AM   #21
Originally Posted by kavermei View Post
I once saw a 10Gohm or so resistor which was encapsulated in a vacuum glass tube... To keep moisture out...
VICTOREEN used to make these.
I have some 1GR 1% in my standards box.
Now made by ohmite I think
Old 30th January 2011, 03:40 PM   #22
Speedskater's Avatar
Electronic Surplus still has some Victoreen parts:
Search Results
Electronic Surplus was only a few miles from the Victoreen plant and would often have surplus parts.
We purchased some of those vacuum glass tube resistors from E.S. they may still have a few.
Kevin
Old 31st January 2011, 11:16 PM   #23
tomchr is offline tomchr  Canada
tomchr's Avatar
Originally Posted by Doz View Post
Yep, spill the beans ... what's it for?
Hello?! What's this for? I'm curious cat here too...
~Tom
Old 31st January 2011, 11:44 PM   #24
Originally Posted by johnferrier View Post
OP is in Denmark, I think but . . .
$5.50 w/expedited shipping five available
ebay: New Vishay FHV-150E-1G00FK 1 GIG 1.5 WATT 1% 100 PPM thick film resistors
Lets see. It would take 39 KV to make 1.5 W in a 1G ohm resistor. I just can't imagine what a 1G ohm resistor would be used for.
Bobby Dipole
Old 1st February 2011, 12:24 AM   #25
johnferrier's Avatar
One use is to measure leakage currents in the nano amp range.
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 1st February 2011, 12:35 AM   #26
HollowState's Avatar
For audio, not much. But it is a common size for range divider networks in high impedance electrometers. Also for sensitive current amplifiers as well as range resistors in megohmmeters. Older Geiger counters use very high megohm resistors on their inputs. Generally on the order of 50 gigohms and up. These were the glass encapsulated types that Victoreen made.
"The further a society drifts from the truth, the more it will hate those who speak it" ~George Orwell
Old 1st February 2011, 02:10 AM   #27
benchtester's Avatar
As said before: just buy one.
Re: what would they be used for? I worked on a product that used a piezo-crystal sensor (inherently AC and capacitive), but they wanted near DC response; so we used the sensor in the feedback loop and the 1 Gigohm resistor as the input resistor IIRC.
Problems: Our resistor was surface mount, and I used lots of alcohol and maybe freon cleaner to make sure it was clean of flux (mostly underneath). Then we encapsulated the whole circuit to avoid humidity effects. We shielded it to avoid responses to static electricity. Something, probably the op amp, was also photosensitive, but the shielding and encapsulation eliminated that issue. All said, it wasn't that bad, if you need it - do it. If you don't need it - then avoid it.
Old 1st February 2011, 06:05 AM   #28
Mouser has them up to 1T. The 1G at 2KV is only $1.50.
Vishay Data Sheet
The 1T will cost you $300.
Old 1st February 2011, 06:58 AM   #29
kavermei's Avatar
Send a message via MSN to kavermei
Wow! Do you mean high energy photons or even UV and visible light?
Never send a human to do a machine's job. --Agent Smith
Old 1st February 2011, 09:17 AM   #30
runebivrin's Avatar
Send a message via MSN to runebivrin
Interesting with the 1/10 watt power rating. That indicates a voltage of 316kV. The plot thickens...
Do wizards use spell checkers?
WTB: 10,000uf or higher 71V or higher caps, max 30mmD KevinLee Swap Meet 1 10th December 2009 12:39 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
