1Gohm or higher resistor ... - Page 2 - diyAudio
Old 29th January 2011, 02:10 AM   #11
eyoung is offline eyoung  United States
eyoung's Avatar
i'm thinking a #3 pencil lead turned on a lathe...
Regards, El
"Lead me not into temptation...I can find it myself."
Old 29th January 2011, 03:53 AM   #12
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
You may find some cheap Chinese condenser microphone with broken capsule on ePay, it should have a pair of them: one for capsule polarization, second for gate leakage.
The Devil is not so terrible as his math model is!
Old 29th January 2011, 07:58 PM   #13
Doz is offline Doz  United Kingdom
Doz's Avatar
Originally Posted by Ty_Bower View Post
I still want to know why he needs such a thing...
Yep, spill the beans ... what's it for?
"To err is human.. to make a real balls-up requires a computer"
Old 29th January 2011, 08:41 PM   #14
johnferrier's Avatar
Regards, El
1G resistors are about $3-4 Digikey or ebay. For homemade, pencil lead sounds like the most promising idea.
Test: hook scope (or other meter) across a 10M resistor and hook it in series to your 1G resistor, and hook the series pair to a source (battery, tone generator, power supply). Measure voltage across 10M to calculate current. Measure your source voltage. With V and I calcuate your R.
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 29th January 2011, 11:08 PM   #15
trobbins's Avatar
John, that test will require one to know the impedance of the meter, as it will shunt the 10M resistor. Typically Flukes are about 10-11M. I think it would be more accurate to use say a 50VDC supply, so that about 0.5V across 10M. Some lab multimeters have 1G input impedance on low voltage DC ranges.
Ciao, Tim
Old 30th January 2011, 12:11 AM   #16
Wavebourn's Avatar
No problem if you have one already known 1G resistor. Connect it, set up input level to get some even reading on your meter, then play with a DIY one to get the same reading.
Old 30th January 2011, 12:12 AM   #17
Ciao, Tim
Good point. If it truly is 10M, then a 10M shunt is not needed at all. Just put the meter in series with the source and 1G resistor. I've used 10V to measure 1G before, so a 9V or 12V battery would work. Have used 1G, 10G, 100G. Gave away a 1T ohm resistor to a diyaudio member. The signal was too noisy to for me to know if I could actually measure that it was 1T ohms.
Old 30th January 2011, 12:24 AM   #18
Ty_Bower's Avatar
I think the next time I place an order with Mouser or DigiKey, I'm going to have to order one of these things. Just in case I need it some day...
SM106031007FE Ohmite Thick Film Resistors
Digi-Key - SM104FE-1000M-ND (Manufacturer - SM104031007FE)
Old 30th January 2011, 12:32 AM   #19
OP is in Denmark, I think but . . .
$5.50 w/expedited shipping five available
ebay: New Vishay FHV-150E-1G00FK 1 GIG 1.5 WATT 1% 100 PPM thick film resistors
Old 30th January 2011, 09:00 AM   #20
kavermei's Avatar
Send a message via MSN to kavermei
I once saw a 10Gohm or so resistor which was encapsulated in a vacuum glass tube... To keep moisture out...
Never send a human to do a machine's job. --Agent Smith
WTB: 10,000uf or higher 71V or higher caps, max 30mmD KevinLee Swap Meet 1 10th December 2009 12:39 AM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 04:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 06:40 AM
screen-plate resistor and grid leak resistor metebalci Tubes / Valves 4 26th February 2004 03:18 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 04:01 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
