diyAudio Sponsor
Old 28th January 2011, 01:51 PM   #1
Troncones's Avatar
Default 6BQ5 Screen Voltage Regulator
Yes I'm still working on the SE 6BQ5 amp. I should have it running an a couple of days.
I thought this may be a good time to look into how to regulate the screen voltage on Pentodes. The power supply I modeled in PSUD II looks stable but I will know more once I run the amp.
Is there a simple (something a Newbie would understand) solid state way to regulate screen voltage?
Would it help the performance?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 28th January 2011, 01:56 PM   #2
mastodon's Avatar
A simple zener (stack) with a resistor should do fine for g2 regulation. Lots of info available, see e.g. here: Zener Diode Voltage Regulator - Electric Circuit
Or use the 6BQ5's in triode mode, but I assume you already have your OPT's, which might get you into trouble if you decide now to change the required load impedance
Old 31st January 2011, 07:31 AM   #3
Why bother, it won't make a useful difference.
Old 31st January 2011, 09:14 AM   #4
SY's Avatar
A quick examination of tube characteristics shows that regulation makes a VERY big difference in pentode circuits.
I use a simple Maida reg, very inexpensive, excellent regulation, and more than quiet enough for this application. You can swipe the reg design right out of the Red Light District amplifier.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 31st January 2011, 09:50 AM   #5
DF96 is offline DF96  England
A pentode screen is both an input and an output. If there is significant impedance there, the output current will generate a voltage which will then be fed in again. This would simply be a source of harmless negative feedback if a pentode was linear. Pentodes, like all valves, are not linear but have a lot of second-order distortion. This second-order, if fed back into g2, mixes with the input signal to create third-order (etc.). In most cases this extra 3rd will be in phase with the intrinsic 3rd produced by the pentode anyway.
Class A SE might not suffer from this effect too much, as at least the pentode will be biased in a reasonably linear part of its characteristic. It gets serious for P-P Class AB/B. Similar issues arise for tetrodes, and tests on RF linears have shown that g2 needs to be fed from a very low impedance: a string of zeners is not good enough, although still popular.
Old 31st January 2011, 11:10 AM   #6
FLT is offline FLT
Putting an Transistor on top of the zeners helps(Mosfet preferred).
Old 31st January 2011, 12:22 PM   #7
How? The problem is the dynamic resistance of the zeners. The exact voltage at g2 does not matter too much, but it must not vary at audio or envelope frequencies.
Old 31st January 2011, 12:59 PM   #8
tubelab.com's Avatar
I use a mosfet source follower biased by a zener or gas tube string. A pot can be used to allow for voltage adjustment. One of my recent projects uses 8 6BQ5's. I use a single zener string feeding 8 seperate mosfets. There are 8 pots tied across the top zener, each feeding a seperate mosfet, which feeds its own screen grid. It is a simple but very effective circuit that allows for individual tube current tweaks since the cathode voltages are all fixed at 12.5 volts.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 31st January 2011, 01:58 PM   #9
Yes, a zener feeding a follower solves the problem. A fat capacitor might do instead, as the main issue is dynamic impedance not exact bias voltage.
Old 1st February 2011, 09:45 AM   #10
Tubelab, that's a very nice little trick for multiple tubes, I like it.
I suspect that the original request was for just a simple single SE, so in the interests of keeping it simple, a resistor and decoupling cap will be perfectly sufficient (or just tie the screen to supply).
6BQ5 Sweet Spot?-Charts for other than 250 Screen Volts? Troncones Tubes / Valves 3 3rd February 2011 02:06 PM
plate and screen voltage screenplate Tubes / Valves 9 10th May 2010 04:11 AM
6V6 SE and Screen Grid Voltage zxx123 Tubes / Valves 5 2nd February 2005 05:36 PM
bias voltage for 6BQ5 plate briansdad Tubes / Valves 3 14th December 2004 06:03 PM
Modifying (Reducing) Screen Voltage gingertube Tubes / Valves 1 14th December 2004 06:10 AM
Page generated in 0.09829 seconds (80.09% PHP - 19.91% MySQL) with 11 queries
