diyAudio Sponsor
Old 26th January 2011, 03:40 PM   #1
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Default aikido heater voltage
I recently built the aikido 9 pin all in one kit.
Aikido 9-Pin All in One Kit
I used 6CG7 tubes. The transformer heater output is 6.3vac. I have one thing that I need some help on. With the tubes out I get 6.3vdc at the heaters as I should. But with the tubes installed the heater voltage drops to 5.5v. The heaters are referenced to 1/4B+. B+ is just over 300v and the heater reference is at 73v. I have been listening like this and the preamp seems to work fine. I just wasn't sure if I needed to address something.
Thanks, Evan
Old 26th January 2011, 03:46 PM   #2
mastodon's Avatar
As long as the transformer doesn't run too hot (you're obviously running it at a higher load than it is intended for), you should be ok. Heater voltage is a bit on the low side, but as long as overall performance is as desired, there should be nothing to worry about.
Old 26th January 2011, 06:36 PM   #3
PWR RYD is offline PWR RYD  United States
PWR RYD's Avatar
Hoping I'm not hijacking this thread, but what if the opposite was true. What if the filament winding was underloaded and the heater voltage was more like 7 Vrms? I know a simple resistor in series can be used to drop the 0.7 V, but is it necessary? Would the higher voltage shorten the tubes life? Thanks.
Old 26th January 2011, 08:12 PM   #4
jgf is offline jgf  United States
It'll work ok with +/- 5% heater voltage, but once you get too far beyond that it won't be optimal. Also, it looks like that's a regulated heater supply on that board, It's likely its dropping out of regulation at low voltage. You might have better luck configuring as a voltage doubler for 12.6 volts, if the board has that option.
Old 26th January 2011, 08:16 PM   #5
7 volts is about as high as my voltage is low. The secondary windings in my transformer are each rated at 4amps. I have the 2 windings paralleled...I don't believe I'm overloading the transformer......
Old 26th January 2011, 08:22 PM   #6
leadbelly's Avatar
Whoa whoa. All you have is an Aikido preamp and it is dragging 8 amps worth of 6.3V down to 5.5V? Somethings not right. What is the primary rating? How sure are you that the secondaries are 6.3V and identical? I would double check that for sure. Could be that 1 winding is actually 5V or that the windings are indeed 6.3V but different VA rating.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 26th January 2011, 08:24 PM   #7
jgf,
Yes the board allows for a voltage doubler. It seemed counterintuitive to me to bring the voltage to 12.6 and then regulate it down to 6.3....but maybe this is what I need to do.
Old 26th January 2011, 08:26 PM   #8
I am using this transformer.
http://www.antekinc.com/pdf/AN-2T230.pdf
I ran the heaters on one winding and two. Same result...
Old 26th January 2011, 08:31 PM   #9
evanc: Not exactly what I meant... some Aikido boards have jumpers to put 6.3v heaters in series for use with 12.6v supply. What are the specs of the transformer you are using? By the way, I had a similar issue with my build when using 6.3v heaters, the reason 12.6 is easier is there is a smaller fraction of 12.6 lost to diode drop than 6.3, IIRC.
Old 26th January 2011, 08:39 PM   #10
Oh I see, 2 windings. It would be worth a try to put them in series for 12.6v. Leadbelly may be right though, maybe something's wrong there. Double check the heater regulator circuit, especially the voltage setting resistor on the reg.
Aikido Heater PSU help Bengali Tubes / Valves 21 22nd February 2010 09:37 PM
Aikido All-In-One Octal Heater Troubles ultrachrome Tubes / Valves 5 6th February 2010 04:31 AM
Regulated Heater on the 6SN7 Aikido Plate to Heater question john65b Tubes / Valves 6 24th November 2009 05:44 AM
aikido heater Stixx Tubes / Valves 23 5th May 2008 01:43 AM
clarification of aikido heater supply jarthel Tubes / Valves 2 23rd May 2006 12:49 AM
Page generated in 0.11136 seconds (79.06% PHP - 20.94% MySQL) with 10 queries
