Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
Thread Tools
Old 25th July 2003, 09:30 PM   #11
Steve Eddy's Avatar
Default Re: silver corrosion
Originally posted by eduard
Hello, In my new monkey amp i want to use some silver wire. Most of the wires will be in the air, so there is no use in using teflon tubing. Can i apply a kind of varnish, like cellulose lacquer to prevent them from corroding. I think that cellulose will not act as a dielectricum so the influence on the signal will be minimal. Anyone has some ideas? Thanks, Ed
Just leave 'em as-is. Silver doesn't corrode in air at room temperature. A few atoms thickness of tarnish isn't going to hurt anything.
se
Old 25th July 2003, 09:32 PM   #12
diyAudio Senior Member
fdegrove's Avatar
How about safety?
Frank
Old 25th July 2003, 09:35 PM   #13
dhaen is offline dhaen
diyAudio Moderator Emeritus
dhaen's Avatar
Default Re: Re: silver corrosion
se
Actually it depends where you are.
I currently work at a green-field site. Most of the silver is still silver after many years of use.
Previously I worked in central London. The silver connectors went black after a year or so.
What I do agree with, is that the black stuff is conductive!
Old 25th July 2003, 09:42 PM   #14
fdegrove's Avatar
Pollution is the enemy here.
Granted silveroxide conducts still fine.
But what's the point of using silver wire to end up listening to silver oxide?
The pic is silver copper oxide, BTW.
Frank
Old 25th July 2003, 09:51 PM   #15
dhaen's Avatar
My word,
That's snazzy wallpaper you've got in your parlour Frank.
Old 25th July 2003, 11:05 PM   #16
Steve Eddy's Avatar
Default Re: Re: Re: silver corrosion
That's not from oxidation. Silver doesn't oxidize in air at room temperature. It's the sulfuric compounds in the air from air pollution that reacts with the silver to produce silver sulfide.
I don't know that it matters whether it's conductive or not. The original poster was planning on putting stuff on the silver which isn't conductive at all. So what's it matter?
se
Old 25th July 2003, 11:11 PM   #17
Steve Eddy's Avatar
Except the pollution isn't creating silver oxide, it's creating silver sulfide.
So which sounds better? A few atoms thickness of silver oxide or vastly greater amounts of polyurethane?
se
Old 25th July 2003, 11:25 PM   #18
fdegrove's Avatar
Never said it to be any different, or did I.
What would you know anyway?
And what makes you think that in your enveronment silver will just bond to oxygen?
Do you want to take chances on your investment? I'd rather play safe on all accounts and prevent the silver from oxidising or chemically react to whatever's in the air and insulate, it's also safer electrically BTW.
Do you're own R&D for a change, I know I did mine years ago already and judging from feedback from the industry it wasn't too bad.
I want my wires to sound the same for the next couple of decades, something you can't guarantee with bare wire, I reckon.
Anything else while you're being oh so knowledgeable?
Frank
Thread Tools
Best way to clean corrosion like this? 454Casull Everything Else 1 4th June 2009 01:37 AM
substance on board, corrosion jol50 Car Audio 37 31st December 2007 01:31 AM
wire corrosion problem trombone Everything Else 4 13th July 2007 04:36 PM
What to use to clean corrosion? still4given Solid State 2 14th March 2005 05:42 PM
Help, light corrosion on PC board eRiCdWoNg Parts 4 18th April 2004 03:29 PM
Page generated in 0.09225392 seconds (83.86% PHP - 16.14% MySQL) with 11 queries
Copyright ©1999-2010 diyAudio
