| diyAudio Sponsor | ||
Hi all - I have a pair of Lumley 120 monoblocks that I have just fitted with an octet of matched KT88 tubes from the USA - I also have Sonus Fabre Signum speakers - an ordered Shanling SCD-T200 and some KUHLTUBE PAIR 396A Western Electric 1973 tubes ordered to go in it when it arrives -
I also have a Mitchel Focus one deck with an SME 3009 MK11 modified tonearm - a new Audio Note M-zero valve pre-amp - now to my problem - I need a valve driven phono amp between the deck and the preamp so I can hear the vinyl playing - there are lots of cheap and nasties out there but with all of the above kit I have obtained over the past ten years I do not want to use them - I can use a soldering iron and many years ago built loads of Elecktor kits - is there something out there that is smallish in size that I can build myself - thank you for reading this - Dewi |
#2 |
Truly small and using tubes/valves is contradictory. The offerings of Bottlehead Corp. are not grotesque in size and seem to mesh with your skill set.
Eli D. |
#3 |
#4 |
Aikido phono?
At long last: the Aikido Phono Preamp Needs a little more DIY ... it'll need a box / transformers etc ...
"To err is human.. to make a real balls-up requires a computer" |
#5 |
sorry I have no idea whether you can get them in kit form
#6 |
Hi, i have a pair of Lumley m120 monoblocks, can anyone advise me what might be a good pre amp to go with these. They sound fantastic and i do not want to spoil them with the wrong choice pre. Also they have winged C 6550A valves X 8 would a change to quality kt88 be an upgrade.
Thanks all Paul |
#7 |
hey-Hey!!!,
So you've got an A-N phono and you want something better? The Bottlehead stuff sounds pretty good. "To err is human.. to make a real balls-up requires a computer" Doz, let me suggest you research the R-101, or perhaps Titanic. No computers then... cheers, Douglas
the Tnuctipun will return |
| Valve pre amp/phono stage | 3GGG | Analog Line Level | 2 | 21st March 2010 11:15 PM |
| Tube phono pre-amp needed. | Runco990 | Tubes / Valves | 28 | 23rd March 2007 03:20 AM |
| Phono pre, valve or jfet | lndm | Analogue Source | 7 | 4th April 2006 02:11 PM |
| valve pre amp | dudemyster | Tubes / Valves | 4 | 13th April 2004 04:13 PM |
| Help/toruble-shooting needed for simple phono pre-amp | bm_mode | Solid State | 16 | 2nd July 2003 03:48 AM |
| Page generated in 0.08997 seconds (83.26% PHP - 16.74% MySQL) with 10 queries |
