| diyAudio Sponsor | ||
Hey,
I'm building my first SE amp from the iron out of an old garbage find console amp (type unknow). The original amp had 9 pin output tubes so I'm assuming they were 6bq5's. Wiring on the empty sockets seem to confirm this. I'm also assuming the output trannys are around 5k primary as the power transformer puts out 184 VAC RMS. I'm using 7c5 output tubes in the new version, because I have a bunch of them. My question is about the output transformers they measure 1.5” H, 2” W, and the coil is about 1.5” thick (5 watts?). The primaries measure 285 Ohms. The secondaries I don't understand (newbie here). There are three wires on the secondary, Gray, Green and Black. Measuring with a Fluke DVM I get: Gray to Green .3 Ohm Gray to Black .5 Ohm Green to Black .7 Ohm On the original chassis Gray and Green wires connected to a speaker socket and the Black wire was soldered directly to the chassis ground. The Black wire does not connect to the frame of the transformer. I haven't seen this before. Anyone have any ideas on why it was wired this way? Thanks in advance. Doogie |
#2 |
Presumably black is the cold end of the secondary and the other two wires are either 4 and 8 ohms or 8 and 16 ohms (first is more likely IMHO based on dcr..)
FWIW I don't get your comment about the black wire..
www.kta-hifi.net |
#3 |
I have amps where the black is soldered to the chassis. Its just a ground wire where the chassis is negative anyway.
#4 |
I've seen this too! The black is common ground, so why can't it be the negative ground also. Doesn't seem to have any effect if its grounded to the chassis or not!
#5 | |
Supply few volts at, say 400 Hz to the primary and take the readings from secondary outputs. (black to grey, black to green and also gray to green) Then you can simply calculate the turns ratios of all three output combinations. The reflected anode impedance can then be calculated: (turns ratio * turns ratio * speaker impedance) Let's assume that the turns ratio (also voltage ratio) from green to black output is 25. Then the anode impedance is 25 * 25 * 8 ohms = 5k. I assume that your trafos have 4 ohms and 8 ohms outputs. Grey to Black is for 4 ohms and Green to Black is for 8 ohms. |
#6 |
Hey,
Wow, thanks much for all the responses. What a wealth of knowledge here! I guess I didn't make myself very clear, or I don't know what I'm doing (more like it), so I drew a crappy schematic for clarification. Given the measurement of the coils in the output transformer this was the way the original transformers were connected. Still seems strange to me that the bottom end of the unused coil connects to ground. Shouldn't the Gray wire connect to the Star Ground , Green wire to + on the speaker and the Black wire left floating? Sorry to trouble you again. Doogie |
#7 | |
The bottom of the coil is ground, most likely there was feedback from one of the taps and this would be referenced to the grounded black tap.. There was probably some connection between the speakers and this point as well. A schematic of the original amplifier would be most useful. When you referenced the black wire did you mean to say chassis instead of (transformer) frame in your post on said subject? To me there is a world of difference, perhaps not so much to some of the others here. As an engineer I read things very literally.
www.kta-hifi.net |
#8 |
Thanks for your patience Kevinkr,
As always when moving into a new culture learning the a new lexicon and semantics confounds the ability to be clear. My reference to the the Black wire not being connected to the frame of the transformer came from seeing a isolation transformer with a shield wire between the coils that connected to the chassis. I tried to be clear that this was not the case on this transformer. I don't have a signal generator so I downloaded a sine wave generator program to my laptop. Set it to 400hz and with all the volume levels cranked measured .812 VRMS out of the headphone jack with a Fluke 70 DMM. The results were similar on both the transformers. Gray - Green = .017 VRMS Gray - Black = .042 VRMS Green - Black = .060 VRMS Hopefully using the formula correctly eg:. .812 / .042 = 19.3 19.3 * 19.3 * 8 = 2980 We get: Gray – Green 18248 Gray – Black 2980 Green – Black 1461 Unfortunately there is not schematic for the amp. I pulled the chassis from the garbage and reverse engineered the empty sockets to find the probable tube types. I was pretty careful when I removed the output transformers to take notes. . My notes indicate that the Gray and Green wires went to a speaker socket and the Black wire was soldered to the chassis. The numbers maybe off due to the .812 VRMS input signal. Yurs Doogie |
#9 |
#10 |
Believe these are SE transformers in which case 5K would be pretty typical for a 6BQ5..
www.kta-hifi.net Last edited by kevinkr; 25th January 2011 at 08:57 PM. |
| Output transformer Question | keithgreenhalgh | Tubes / Valves | 14 | 3rd August 2008 02:42 PM |
| Output Transformer Question? | Cloth Ears | Tubes / Valves | 9 | 3rd April 2007 04:37 PM |
| 1:1 output transformer question | Tyimo | Solid State | 31 | 16th January 2007 01:14 PM |
| Output Transformer Question | 316a | Tubes / Valves | 3 | 14th June 2004 02:58 PM |
| Page generated in 0.14207 seconds (74.09% PHP - 25.91% MySQL) with 11 queries |
