| diyAudio Sponsor | ||
I'm using a tube amp in my Stereo/HT system. Between music and TV, the amp is on 14 hours a day. Would it be easier on the amp to just leave it on all the time?
Bobby Dipole |
#2 |
Leaving the amp on for ten hours a day without using it is an insane waste of energy and money. The filaments wear when they're on. But they're also stressed at start-up. With one start-up per day I bet the regular filament wear during normal operation of the amp is the dominant factor in filament, hence, tube life. I say turn the amp off when you don't need it.
~Tom |
#3 |
#4 |
I am lucky if I average 14min a day
![]() Poor Tube amp doesn't even warm up enough to hit its stride. |
#5 |
RIP
If I've been working on it, I turn it off ... just because I know me ... I think.
#6 |
Custom Title
I often leave them on but it switches up. Balance between being warm and ready to rock, and saving tube life.... though start up cycles are stressful too... so it's a mix. Unless I have big tube gear in the rig, then it gets shut down. Like when I had a tube linestage into a tube crossover, running 2 stereo tubeamps....
That got almost always shut down)
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#7 |
You only consider tube life. The other components will deteriorate with higher temperatures, capacitors and insulation and of course the pilot lamps. And corrosion action accelerates. Not to speak of the energy wasted. Well, you aren't wasting it if it's winter but in the summer it's not a good thing.
I suggest that if you don't listen for at least a half hour, shut it off. |
#8 |
I would turn off when sleeping or gone for safety reasons.
mike - www.keepingsundayspecial.org |
#9 |
There ain't 14 hours a week of TV worth watching and most of what is worth watching does not need anything special for the audio. I would rethink your whole plan. Only use tubes for the best of the best!
#10 |
Tubie Noobie
I would turn it off as well. Energy, Safety, Peace fo Mind.
Pretty interesting when a spider gets in the case. I am just glad it was small. Made quite the show.
Living Life Doing the Waltz in 4/4 meter. |
| Page generated in 0.10598 seconds (80.27% PHP - 19.73% MySQL) with 9 queries |
