diyAudio Sponsor
Old 24th January 2011, 04:06 PM   #1
Miniwatt's Avatar
Default Negative supply with CT tranny
L.S.
I'm putting together a new amp with old iron. The power xformer has a center tap, but the xformer in the original schematic doesn't.
No problem for the HT, but I'm not so familiar with negative supplies, especially how it's done here:
So my question is: how do I adapt this to a CT transformer?
Thanks!
Old 24th January 2011, 04:42 PM   #2
Mooly's Avatar
It's usually the SS forums I frequent but no matter. What's the secondary voltages of the new CT tranny ? It would need to be a 300-0-300 to use the CT as the ground. The CT would go to ground, (Your bridge is shown reversed by the way). So CT to ground, positive output from bridge to +400v and negative side of bridge to -400v The two diodes and 22uf are ommited. Diodes in the bridge drawn reversed
Also you don't need adapt... if the secondary voltage is correct you can ignore the CT. So if it's 150-0-150 just ignore the CT.
A simulation free zone. Design it, build it, test it.
Old 24th January 2011, 04:45 PM   #3
DF96 is offline DF96  England
Assuming the centre-tap will be grounded, it is actually simpler. You know how to build a positive supply from a CT transformer with two diodes. Just do the same thing for a negative supply, with the diodes reversed. The four diodes can be combined in a bridge, but the wiring will be different from that shown above.
Old 24th January 2011, 05:19 PM   #4
Miniwatt's Avatar
Thanks a lot, guys! Really appreciate it.
I just ate so my brain is on standby now, but I'll let it sink in.
Need a Pioneer SA-9800 Supply Tranny jritota Solid State 4 8th February 2010 04:05 PM
Using single CT supply with LM3886 TDWesty Power Supplies 0 15th March 2007 04:37 AM
CT phono power supply modder Analogue Source 1 13th August 2006 08:26 PM
power supply tranny memphissound Tubes / Valves 13 21st January 2006 11:19 PM
Tranny CT scheme? Altaic Solid State 2 5th August 2002 08:03 PM
Page generated in 0.07603 seconds (83.94% PHP - 16.06% MySQL) with 11 queries
