diyAudio Sponsor
Old 23rd January 2011, 12:10 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default TF110-48/UL in the UK?
Currently contemplating a tube project and wondered if that output transformer was available in the UK? This is my first tube project so I don't know many suppliers and such.
Boscoe
I thought about it once, but then thought again.
Old 23rd January 2011, 04:05 PM   #2
By any chance, are you considering building an "El Cheapo" (schematic attached)? That "piece of iron" ceased being a bargain some time ago. Sowter is UK resident and makes a superb, if costly, product. Their model U064 would work for a triode wired setup, as shown in the drawing.
You will have to work the expense numbers for yourself to see if importation from the US makes sense. The "budget" O/P trafo I currently recommend in building an EC is Edcor's model CXPP25-6-7.6K, which is substantial enough for use with UL mode "finals".
Eli D.
Old 23rd January 2011, 04:11 PM   #3
Okay nice one thanks but I'm doing a different design to the 'el cheapo'.
Old 23rd January 2011, 04:38 PM   #4
Post the schematic, please.
Eli D.
Old 23rd January 2011, 06:17 PM   #5
There you go. This is only an idea it can be changed to a different design.
Old 24th January 2011, 04:15 AM   #6
A UL mode PP pair of "12" W. tubes, like the 6BQ5, is good for approx. 12 honest W., in combination with a separate phase splitter. Self splitting limits the O/P to 1/2 of yield from a separate splitter. The claim of an 8 W. O/P is VERY ambitious.
Eli D.
Old 24th January 2011, 06:55 AM   #7
Okay fair enough, I was actually looking for a push-pull design could you help me out with that?
Old 24th January 2011, 07:21 AM   #8
Doz is offline Doz  United Kingdom
Doz's Avatar
Hammond stuff is available in the UK from www.bluebellaudio.com
Edcor will ship to the UK without problem.
Sowter stuff tends to be very pricey, and I had a bad experience once.
"To err is human.. to make a real balls-up requires a computer"
Old 24th January 2011, 08:14 AM   #9
Hey
I have used some of Mike's transformers.
Valves And Transformers (Contents)
He is updating the homepage in the moment, so there is some dead links.
Benny
Old 24th January 2011, 08:58 PM   #10
Doz's Avatar
Originally Posted by Hojvaelde View Post
Hey
Benny
Were these formerly supplied as "Danbury" transformers? I used a good few of them before Maplin stopped stocking them.
Sell Labtool-48 redhorseaudio Swap Meet 0 8th May 2008 10:28 AM
Mltl-48 keladrin Full Range 1 23rd October 2007 03:57 PM
GM JX92S MLTL-48 Triangle (JIT for UK Meet) Mr Chris Full Range 34 20th August 2007 12:46 PM
833 and GU-48 Eugeny Tubes / Valves 1 1st April 2005 05:35 AM
gu-48 PP Bernd Tubes / Valves 14 13th May 2004 02:24 AM
Page generated in 0.10739 seconds (77.13% PHP - 22.87% MySQL) with 11 queries
