diyAudio Sponsor
Old 23rd January 2011, 12:47 AM   #1
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Default Fuses...what's the deal?
So I'm putting my preamp into its chasis today and I get to the fuse holders for the wall current. I'm hooking up 12ga from the wall and fairly large wire to the transformer and than there are the fuses. I installed 2amp glass tube fuses. the wire in it is tiny......Is this something that is considered? Is there a certain type that is better than another?
Old 23rd January 2011, 01:16 AM   #2
It has to be that way to work. The total resistance of a wire is a function of diameter and length anyway. A 1/4" length doesn't have to be nearly as big as a 25' length. Don't worry about it.
mike - www.keepingsundayspecial.org
Old 23rd January 2011, 02:19 AM   #3
boywonder's Avatar
Slo-blo fuses will survive high in-rush currents where fast blow types of the same current rating will pop. If you have lots of power supply capacitance, you can have high in-rush current.
Old 23rd January 2011, 02:34 AM   #4
Ty_Bower's Avatar
Click the image to open in full size.?
Old 23rd January 2011, 02:41 AM   #5
aardvarkash10's Avatar
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 23rd January 2011, 05:10 AM   #6
tomchr is offline tomchr  United States
tomchr's Avatar
Take the VA rating and divide it by your nominal mains voltage. Multiply by 1.33. That's your fuse rating. Use a slow-blow fuse. If the fuse still blows on turn-on, install a soft-start circuit.
So for, say a 200 VA transformer running on a 120 V system, the appropriate fuse would be: (200/120)*1.33 = 2.22 A. So use a 2 A or 2.5 A fuse (standard values).
~Tom
Old 23rd January 2011, 12:21 PM   #7
Thanks for the replies. I use a soft start...no blown fuses. I was more thinking about the bottleneck of the tiny wire in the fuse. Slo-blo fuses look to have a longer length of tiny wire coiled up in them. Thanks again...Evan
Old 23rd January 2011, 02:42 PM   #8
DF96 is offline DF96  England
The electrons might slow down at the bottleneck, but they will cope. Electrons are very flexible like that.
Old 23rd January 2011, 02:48 PM   #9
mastodon's Avatar
For a moment, I thought this thread was going to be about which type of fuse makes for the best sound.
Old 23rd January 2011, 02:54 PM   #10
It is, isn't it? The suggestion is that you use massive solid platinum cable to wire up your amp to the mains, then pass the current through a filament as thick as a human hair. Why use the massive mains cable at all?
looks like a deal to me ZippyTs Car Audio 6 8th February 2010 07:55 PM
What a Deal! jkeny Tubes / Valves 3 25th March 2009 09:36 PM
Page generated in 0.10982 seconds (77.54% PHP - 22.46% MySQL) with 10 queries
