| diyAudio Sponsor | ||
Hi all
Ok, so I have some leftover transformers that are looking for a project and I donīt know what to make with them. Do you have any suggestions? I have just compleated a KT88 based amp so this is no option. I would like to use them in an stereo integrated amp. Power Transformer: Primary: 230VAC Sec: 1x390V 0,5A 2x5V 2A 2x6,3V 4A 2x3,15-0-3,15V 2A 1x40V 0,1A Output transformers: PP 4K Cheers
/H Last edited by h00hbt; 22nd January 2011 at 08:18 PM. |
#2 |
You could consider a fixed bias KT88 triode push pull amp; will give you some 15 watts of power.
#3 |
It screams push-pull EL34 with fixed bias to me. That's probably not a heck of a lot different than your previous KT88 project though.
..Todd |
#4 |
Single ended 300B, 2A3, 45, etc? Can use a choke input to get a lower voltage, or tune the B+ with the cap. Or do SE with a pentode.
#5 |
Or a PP with real triodes.
#6 |
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#7 |
#8 | |
http://www.electronicslab.ph/forum/i...?topic=32688.0 |
#9 |
Don't know about that power xfmr, but that 4K P-2-P OPT would work nicely with 6BQ6GA/GTB finals.
#10 | |
Yes! this is what I was thinking too but would 4K OPTīs work? You donīt happen to have a stereo integrated PP EL34 schematic somewhere? Cheers
/H |
| Leftover-sunday! big fun | KaffiMann | Multi-Way | 2 | 19th April 2010 04:41 AM |
| subwoofer TL with leftover wood | krikus050 | Multi-Way | 12 | 18th July 2008 12:52 AM |
| leftover drivers= potential project? | xstephanx | Full Range | 2 | 4th March 2005 02:56 PM |
| What to do with my leftover Toshibas | BrianDonegan | Solid State | 6 | 22nd January 2005 08:52 AM |
| Page generated in 0.10925 seconds (73.08% PHP - 26.92% MySQL) with 11 queries |
