| diyAudio Sponsor | ||
I need help attaching the wires(+,-) from the reverb pot to the SPK003 circuit board. They were un-attached when I got the amp. Any help is greatly appreciated. |
#2 |
Hi, As far as I can tell from the schematic ,reverb pot 500K ohm has
3 terminals, one to pin 35 of spk003 board and live terminal of jack. Center leg to pin 12 of spk002 board.Third one to ground. You have to check the pot that when you turn fully anticlockwise to get maximum ohm or minimum ohm? and vice versa with a meter between one or the other pin with the center pin because the 2 extreme pins will read maximum as rated on the pot.eg.500K ohm either way. Try it one way or the other. PS where does the + and - go to the pot? Singa Last edited by singa; 22nd January 2011 at 08:07 AM. |
#3 |
Thank you singa! Finding my way around that architecture from the schematic was too foreign for me.
| Help reading schematic | Renron | Multi-Way | 14 | 15th January 2008 08:31 PM |
| Trouble Reading Blueprints For Fostex Recommended Enclosure | kelticwizard | Multi-Way | 2 | 13th April 2007 03:18 AM |
| Schematic Reading Help | orson198305 | Instruments and Amps | 9 | 26th May 2006 03:23 AM |
| need schematic reading help | jaymanaa | Tubes / Valves | 2 | 7th January 2006 11:57 PM |
| Some trouble reading schematics | TStrong_06 | Tubes / Valves | 55 | 15th January 2003 12:18 AM |
| Page generated in 0.09086 seconds (69.16% PHP - 30.84% MySQL) with 11 queries |
