diyAudio Sponsor
Old 19th January 2011, 01:09 AM   #1
Tubologic's Avatar
Default Can a 7625 Ceramic Planar Triode be soldered ?
Does anybody here have experience with small ceramic planar tubes ? I would like to use a 7625 planar triode but can't find a socket for it and the G.E datasheet doesn't mention any specific socket for this tube. It has small lateral pins (different from the 7077 who needs contact springs) which could be easily soldered on a PCB but I'm afraid to damage this (very expensive) tube by overheating it. Looks this tube was designed to be direct soldered into the circuit but I'm not sure. Your well informed advices are welcome.
Old 19th January 2011, 01:15 AM   #2
nigelwright7557's Avatar
Hold the pin on the top of the pcb with pliers while soldering underneath.
This will prevent heat reaching the tube.
Might be a two person job tho.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 19th January 2011, 11:31 AM   #3
bigwill is offline bigwill  United Kingdom
That's the coolest little tube! What do the curves look like?
Edit: I found the data sheet on this site if anyone's interested http://www.classiccmp.org/rtellason/tubes.html
Not the most linear but not too bad, I want to play with some now
Old 19th January 2011, 02:37 PM   #4
pjp is offline pjp  India
pjp's Avatar
Tubologic, on the datasheet linked to by bigwill, it says "envelope temperature at hottest point: 250șC".
I think soldering will be a very risky thing to do. Those metal-ceramic joints are very fragile indeed.
I'm sure you can repurpose a socket from some other thing.
Old 19th January 2011, 03:02 PM   #5
Tom Bavis's Avatar
60/40 tin-lead solder melts at 183C. Tube seals won't reach the temperature of pins - should be fine. Don't use this if you must be RoHS compliant though... lead free is generally soldered at 250-270C.
Old 19th January 2011, 03:26 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
I don't know about 7625, but 6S17K-V has electrodes made of silver coated titanium, no problems with soldering.
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 19th January 2011, 03:54 PM   #7
sycorax is offline sycorax  Netherlands
sycorax's Avatar
Datasheets says Printed Circuit Board solder slugs:
Base Side contacts
Filament Vf 6.3 Volts / If: 0.24 Ampere / -: Indirect /
Description Ceramic and metal high mu triode intended for low-level audio applications. PCB solder lugs. Mu 80
Literature Essential Characteristics, GE 1973
- - Manufacturers Literature
DIY CD2M-PRO -> AKM4397 DAC -> Aikido pre -> GM70PP mono -> Martin Logan Vantage ESL -> Me!
Old 19th January 2011, 04:06 PM   #8
sycorax's Avatar
I think that 250 degrees Celsius is the maximum operating temperature, normally Ceramic tubes are High power High power and High temperature.
The pdf is a publication intended for radio hams. The tube is relatively immune to nuclear radiation so you can continue with listen to music after the blast:-)
Interesting pdf:
http://n4trb.com/AmateurRadio/GE_Ham...5%20No%203.pdf
Lucar connector or soldered joints for drivers LostForWords Full Range 5 21st February 2010 11:18 PM
FS: PCM2706 (soldered onto converter) user_manutd Swap Meet 0 13th May 2009 01:41 AM
For Sale: Balanced Line Stage PCB all soldered FrancoB Swap Meet 2 18th February 2005 11:53 PM
Gold or silver plating soldered boards? Petter Parts 33 6th October 2002 05:56 PM
Page generated in 0.10480 seconds (74.07% PHP - 25.93% MySQL) with 11 queries
