| diyAudio Sponsor | ||
I use A EZ81 rectifier for my 10Y driver tube's on my 45 SE amp , are there other 6.3v rectifiers known that are better sounding
#2 |
If you can find it try the gold pin version of it.
miklos |
#3 |
no, the EZ81 is the pinnacle of sonic engineering.
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#4 |
If possible find one which has been broken in gently by being used in an EZ80 position for about 50 hours.
#5 |
...should this be encouraged?
I mean, what, if any, hard information is available at this point to make a recommendation on eg the op's power supply configuration, loading, voltages, a definition of "better" or at the least an understanding of the perceived shortcomings of the current device, ANYTHING? Even, god forbid, some indication of the manfacturer of the existing device? Or is it reasonable to just shuffle around in the dark throwing random recommendations out for the consumption of anyone who stumbles into the thread?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 Last edited by aardvarkash10; 18th January 2011 at 07:25 PM. |
#6 |
Every comment is relevant wrt sonic performance, especially to my golden ears that perceive all sounds, and with a clarity and smoothness that improves in the dark. However technically, I always recommend swapping the heater/filament wires around - that usually provides a significant improvement.
#8 |
This is the one you want. It sounds the best.
![]() http://s69.photobucket.com/albums/i4...6CA4bottom.jpg http://s69.photobucket.com/albums/i4...Tubes/6CA4.jpg |
#9 |
let me guess Ty - lows are lower, highs are higher, soundstage is wider and deeper and musical artifacts leap out where you have never noticed them before.
The device cancels extraneous noise from outside your listening space and books you the best seats at MSG for a reunion concert with Ella Fitzgerald and Fats Domino. It also cures dandruff.
#10 | |
ps my baldness assures impartiality |
| WTT: Various tubes for 6CA4/EZ81 rectifier tubes | GordonW | Swap Meet | 4 | 27th August 2008 12:37 AM |
| EZ81 rectifier noise | Stixx | Tubes / Valves | 24 | 22nd December 2007 07:25 PM |
| Changing from 6X4 to EZ81 | Mrpong | Tubes / Valves | 3 | 30th June 2006 11:34 AM |
| WTB: 6ca4/EZ81 Rectifier Tubes | mrdon | Swap Meet | 2 | 10th January 2006 01:28 AM |
| EZ81 tube rectifier | kephaudio | Tubes / Valves | 13 | 29th March 2005 12:44 AM |
| Page generated in 0.10954 seconds (77.85% PHP - 22.15% MySQL) with 10 queries |
