| diyAudio Sponsor | ||
Any thoughts on the max. capacitance value? I've got 4 in a bridge , and was thinking of 100uF
#4 |
работник
PSUDii has a 6CJ3 built-in. The dynamic behaviour of these are very similar to PY500A - so you can simulate with your load, and see that the peaks are not above 1000mA, as per the PY spec.
IT's a fine rectifier, but best with choke input, IMHO. |
#5 | |
316A |
#6 |
Thanks... choke input isn't an option here I'm afraid
#7 |
1000mA ? My sheet says 800mA ..
#8 |
PY500a is listed in my list, probably got it from here: PSUD rectifier list
Real tubes have top-caps |
#9 |
работник
#10 | |
Anyhow , I should be able to put 220uF as the first cap without issues ... more than enough and then some ... the bottle count for this project is getting out of hand |
| py500A question | kathodyne | Tubes / Valves | 2 | 3rd February 2006 07:13 PM |
| Page generated in 0.10327 seconds (76.47% PHP - 23.53% MySQL) with 10 queries |
