DRD Amps
DRD Amps
Old 24th July 2003, 03:13 PM   #1
Peter Menting is offline Peter Menting  United States
Thumbs up DRD Amps
Hello to all! Just getting back into tubes and it's great to read your posts and see what's new. Just finishing a Dyna 70 clone to kind of get back into the thick of it, but am interested in DRD SET amp thing. Read Bill Gaw's review of Jack Eliano's amp as well as Ron Welbourne's comments, but I would like to hear opinions from the "serious folk" as well as suggestions, tech data etc. Hope to hear from y'all.
Pete
Old 24th July 2003, 06:30 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Peter,
Please excuse my ignorance, DRD?
Old 24th July 2003, 06:39 PM   #3
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello, with search button you can find some information about this circuit using the word monkey. Right now i am building one with e80cc ( one half ) and vt-25. I am very curious what it will do in my system. Usually people will use more powerfull tubes. But in the end i will only use it above 600 hetz with a Tad-2001 horn. Succes, Ed
Old 24th July 2003, 06:49 PM   #4
dhaen's Avatar
Aha,
Direct Reactance Drive! Yes..of course..
Unfortunately no experience yet. - sorry.
However, I'm dying to try one, and probably will this year.
There have been a couple of threads in the last couple of months:
A Choked Monkey Please!
and
Chokless Monkey
Old 24th July 2003, 06:59 PM   #5
Picked up the notation from the Electroprint site, short for "Direct Reactance Drive". It is a 300B amp by Jack Eliano using what I would describe as a plate loading choke for the driver (6N1P or 6AQ8) instead of the normal R-C coupling, and also couples the primary return of the OPT directly to the 300B Cathode through an oil filled cap. Fascinated by two things; (1) the simplicity of the circuit (I counted only 12 components in the amp section-including the tubes!) and (2) It appears to isolate the Power Supply from the signal amp. There are also claims for more output (12Watts?) from this circuit topology. Don't know of anyone who has heard one, would love to know if it sounds as good as it looks!
Old 24th July 2003, 07:01 PM   #6
John thanks for the scoop and Ed I would like to know how your project turns out. Thanks again to you both.
Pete
Old 24th July 2003, 09:40 PM   #7
Bas Horneman is offline Bas Horneman  Netherlands
Bas Horneman's Avatar
Hi Peter,
That is the Ultrapath part of the DRD. Theoretically it does "isolate" the PSU from the amp...but not completely. Differences in SS rectification/Tube rectification will all be heard I'm sure...but that is just a little sidenote.
Just like Dhaen I've been dying to do a DRD as well. Building your own is slightly harder the it seems at first, as several threads at the AA and here have shown me.
Bas
Old 24th July 2003, 09:49 PM   #8
dhaen's Avatar
Bas,
Did you ever ask Wil to wind you a choke?
Old 24th July 2003, 09:53 PM   #9
Hi John,
Nope, not yet...gave my phono project priority...
Bas
plus want to do something on the cheap...not that Wil is expensive.. so probably something parafeed with 10:1 toro´dals will happen before the DRD..But I allready have sockets and 300b's for my DRD and some 7N7 or 7AF7 as drivers.
Your 845 amp up and running yet?
Old 24th July 2003, 10:01 PM   #10
dhaen's Avatar
Default monkeying around....
Hi Bas,
How is your Phono project?
My 845 is beautiful, except that the PSU is still spread all over the bench
Actually I just fixed someones 211 SE amp. Wow it sounds sweet!
I suppose I'll have to tell him it's fixed soon.....
DRD AmpsHide this!Advertise here!
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 01:23 PM
For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! opc Swap Meet 23 2nd November 2009 06:04 PM
Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest mbcouple Swap Meet 2 27th October 2008 11:27 PM
Why do some Bogan amps sound so good as guitar amps? amperex Instruments and Amps 7 22nd June 2006 12:46 PM
Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? percy Chip Amps 31 13th January 2006 02:33 AM
