Sn/Pb S-Sn/Cu ... - Page 3 - diyAudio
Old 18th January 2011, 03:56 AM   #21
Cardas Quad Eutectic.
You're welcome.
Poinz
Old 18th January 2011, 04:01 PM   #22
M Gregg is offline M Gregg  England
You're welcome.
Poinz
Please expand your comment?
Have you had problems?
M. Gregg
Old 18th January 2011, 05:33 PM   #23
Michael Koster's Avatar
"The first 3.5ís did not flush worth a crap."
LOL!
two words: Siphon Jet...
Eutectic solder may at the end of the day produce better solder joints because it has less of the mushy phase. "Cold" solder joints can be caused by the solder being disturbed during the mushy phase.
Old 20th January 2011, 04:59 AM   #24
agdr is offline agdr  United States
agdr's Avatar
I had to buy some more Cardas Quad today and while Google searching found some interesting marketing spin on a Cardas Tri product page. The retailer claims the phone company had to reheat joints made with 60/40 solder every year, for reliability, until eutectic 63/37 solder was discovered.
" When the phone company used this type of solder on their main frames, every joint had to be reheated once a year to insure reliability."
Cardas Tri Eutectic Lead Free Silver Solder Roll 100gm by Revolution Power
It would be interesting to know if there is any historical truth to that...
-agdr
Old 20th January 2011, 05:55 AM   #25
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
We never reheated anything back in U.S.S.R. Solder was used POS-61, it contained Antimony, 0.5%; Tin, 61%; and Lead, 39.5%
For electronics organic pine rosin was used. I still remember that smell...
Edit: there was so called Solder type A, but it was used for phone cables only. It was exactly 63/37.
The Devil is not so terrible as his math model is!
Old 20th January 2011, 11:34 AM   #26
Solder giving 101%....
cheers,
Douglas
the Tnuctipun will return
Old 20th January 2011, 11:55 AM   #27
Doz is offline Doz  United Kingdom
Doz's Avatar
Originally Posted by Hearinspace View Post
Well, then there's this issue. Nasa thinks enough of the subject to have a whole web-page on it.
That's what kills old OCxx transistors ... tap 'em to break the whisker and off they go again (for a while)
"To err is human.. to make a real balls-up requires a computer"
Old 20th January 2011, 12:33 PM   #28
AndrewT is online now AndrewT  Scotland
60/40 is a general purpose solder with a pasty range for a little workability.
For soldering electronic components use a eutectic designed for soldering electronic components.
The cheapest and easiest available eutectic is 63/37.
There are many others but all are more expensive and less likely to be widely available.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th January 2011, 03:19 PM   #29
boywonder's Avatar
-agdr
Here are a few other snippets from that marketing pitch:
"Today, all printed circuit boards use 63/37 eutectic solder.".......not if they are ROHS compliant.
"Cardas reports never having, or hearing of, a single failure in one of these joints.".....well George apparently hasn't seen any of my solder work
Old 20th January 2011, 04:38 PM   #30
I am using leaded WBT 4% silver - excellent stuff
WBT 4% SILVER SOLDER (Lead based)
By the way old marry days in the USSR I was taught that silver is must for a good solder :-)
All quiet on the SN front - about darned time! cbutterworth Tubes / Valves 12 1st December 2007 04:53 PM
Wanted: P-Audio SN-8MB speakers NED 209 Swap Meet 0 1st May 2007 12:56 AM
convert Lead Pb-206 to Pb-205 jacquesl Everything Else 2 4th February 2007 11:39 AM
All quiet on the SN front - recommended choice of tubes cbutterworth Tubes / Valves 4 29th January 2007 11:40 PM
Pb / Pb-free DragonMaster Everything Else 29 11th January 2006 12:48 PM
Copyright ©1999-2017 diyAudio
