Tube bass preamplifier power supply (Need Help) - Page 2 - diyAudio
Old 18th January 2011, 04:49 PM   #11
Estimated source resistance and load resistor. Do those probe values at the load resistor look realistic? This is approximately 8 seconds in.
Old 18th January 2011, 05:15 PM   #12
ruffrecords's Avatar
The 383uV ripple looks a little high to me given you only have a 3mA load.
I don't use LC filters so I cannot comment on the design details but I would have thought C2 at 0.1uF was rather low. Try it at 100uF and see what you get.
Cheers
Ian
Old 20th January 2011, 02:05 AM   #13
Much better! Although I don't know if I can find a 470uF cap that will fit in my 2U chassis, I will go as large as I can. Can you see any improvements? I am planning on having a voltage divider on the output so I can dial in a good B+ voltage.
Old 20th January 2011, 02:59 AM   #14
Sorry; this is hard to read. I'm trying to find the voltage ratings of caps that I need. I want PCB mountable radial caps. The probes read 352V at steady state. I can get 400V caps. Is this safe to assume? I can dish out a bit more money, but sacrifice some space. My transformer is rated at 250VAC, but this is RMS and it isn't loaded.
Thank you, have a good day.
Old 20th January 2011, 11:22 AM   #15
I use 400V caps for this kind of supply all the time but I also sometimes use 450V types. Both are commonly used in SMPSUs and are readily available at reasonable prices.
Cheers
Ian
Old 22nd January 2011, 09:18 PM   #16
Thanks Ian. How do you feel about this layout? I haven't done the AC input and B+ output pads yet.
Old 23rd January 2011, 12:17 AM   #17
I have done a similar layout for an RC only power HT power supply. I have all the cap -ve pins in the middle so you can run a nice short fat 0V trace up the middle, but other than that it is pretty similar.
Cheers
Ian
Old 23rd January 2011, 12:26 AM   #18
nigelwright7557's Avatar
Fatter tracks please !
A groundplane wouldnt go amiss, fill in with as much copper as possible.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 23rd January 2011, 01:36 AM   #19
Thank you guys. I will run the copper all the way to the boarders of the board.
Old 23rd January 2011, 02:17 AM   #20
Should I worry about having channels too narrow? My grid is 50mils, so the closest points are about 30mils apart. Is that a problem?
Preamplifier Power Supply Problems FlyAndy Solid State 2 24th November 2010 07:54 PM
Power Supply for Preamplifier skogs Solid State 15 15th June 2007 02:16 PM
Which is the better power supply for a preamplifier? fotios Solid State 16 2nd March 2007 08:35 PM
FS : Battery Supply Tube Preamplifier (12V SMPS to 275V) ANALOG GUY Swap Meet 0 30th October 2006 09:38 AM
Tube preamplifier & Solid State power amplifier for guitar Dusk Instruments and Amps 2 13th October 2004 10:48 AM
Copyright 1999-2017 diyAudio
