| diyAudio Sponsor | ||
hello everyone,
I was planning a DIY 6C33C PP. this is the circuit I intend to do, but I'm afraid there are some errors in it. please let me know this circuit is okay? |
#2 | |
2. An input capacity 6S33S is large, so the plate current of driver tube is necessary to be done more. 3. It is better to do FT3 in 3-4 times more. |
#3 |
Well a few things that come to mind.
First here is a cap on the cathode tail resistor of the phase splitter that shouldn't be there. Second I should think the 6H30 would do a much better job driving the 6C33 than a 12BH7. I would want a low impedance and lots of current to drive the grids of a 6C33.. I'd even consider an IT in this application. Third the 6C33 is best run with cathode bias - if you use fixed bias you will need to delay the B+ until the filaments are fully warmed up to prevent arcing. Operating stability is less of a given with fixed bias with this tube, although I prefer fixed bias in general. The grid resistors are missing on the output stage. Not really crazy about this design.
www.kta-hifi.net Last edited by kevinkr; 14th January 2011 at 06:05 PM. |
| 6C33C-B. PP or SE ? | Predator864 | Tubes / Valves | 471 | 14th February 2011 09:30 PM |
| 6C33C schematic | Hesky | Tubes / Valves | 76 | 15th May 2010 07:23 AM |
| A request for PP 6c33c Schematics | JoshK | Tubes / Valves | 37 | 6th July 2006 04:00 AM |
| EL84 PP Diy. Pls help me!!! | BigOx | Tubes / Valves | 24 | 11th June 2006 06:09 AM |
| Page generated in 0.08000 seconds (73.73% PHP - 26.27% MySQL) with 11 queries |
