Loud Noise due to NFB
Old 15th January 2011, 06:10 PM   #11
sonata149 is offline sonata149  Malta
Thanks artosalo for your concise but comprehensive explanation. I'm learning things with every project I make (all of them had problems about which I posted here)!!! I will solder a 1nF across the 6K8 NFB resistor as with longer playing the HF is verging on slight distortion. My speakers are very revealing in the HF range (Yams NS-1000).
Best regards.
Old 15th January 2011, 07:42 PM   #12
DF96 is offline DF96  England
1nF will give you -3dB at 24kHz.
Old 15th January 2011, 08:06 PM   #13
Hi DF, that's quite a high frequency? Does that mean I should use a smaller cap (say 560 or 680pF) for the attenuation of a frequency more within the audible range (say in the 15 to 18 kHz range)? How do you calculate the value? Thanks for your time and input.
Best regards to all.
Old 15th January 2011, 08:36 PM   #14
Formula is f = 1 / (2 pi C R) so to get a lower cutoff you need a bigger cap.
It might be better to find why you are getting HF distortion. Many modern speakers have a HF lift, so does some modern music. I'm not sure why - maybe intended to impress people rather than sound good.
Old 15th January 2011, 09:06 PM   #15
artosalo is offline artosalo  Finland
artosalo's Avatar
True. This has no effection in the audible frequency range in normal case.
My assumption was that the problem is caused by NFB-loop and there may exist ringing at the transients, which in turn could do something to higer discants.
1nF accross the NFB-resistor could decrease this effect.
Old 17th April 2012, 05:08 PM   #16
Default Trioding EF86 in JC Morrison's 6L6GC SE amp
Has anyone trioded the EF86 in this amplifier? In the original circuit the amp is quite sensitive and I wouldn't mind some attenuation to complement my preamp's output. I know I can bypass the preamp but I am quite happy with it.
Not being technical can someone please outline the specific procedure for triode operation - circuit diagram in post# 1.
What component changes need to be made? Is the negative feedback affected by such a change? If yes, how to go about it? The remaining sections I would suppose will remain the same, no?
Thanks for your patience with a complete layman in electronics.
Best regards.
Loud Noise due to NFBHide this!Advertise here!
How loud is 250uV white noise? 81bas Solid State 5 9th April 2010 06:43 PM
Carver M-1.5t loud noise on one channel hybridge Solid State 1 25th March 2010 01:09 AM
buzz noise from loud speakers vibeline Multi-Way 9 7th January 2007 07:19 PM
Carver M1.0t Loud "tong tong" noise Visigoth Solid State 9 4th January 2006 01:17 AM
Reduce NFB but keep noise/hum down? K-amps Solid State 12 17th March 2005 10:47 PM
