| diyAudio Sponsor | ||
Hello all,
Well, I'm hanging my head in shame. I've gone and swapped over some speakers and I left the amp on in the process. Complete twit, but it's done now. The instruction manual for the amp specifically warns of damage if this is done. Having connected the amp back up to the new speakers there is a slight hum coming from the speakers that wasn't there before. It doesn't vary with volume. You can also hear the faint metallic sounds of the valves as they warm up, and some scratching. The pre-amp valves produce a sharp sound when tapped lightly. Does anyone have a clue what, if anything, I may have cooked? Anyone know what damage to inspect for specifically? Thanks for reading and any words of wisdom. I'm off to the naughty step. |
#2 |
In this case probably nothing. Usually the damage that occurs is a fried output transformer which is stunningly obvious. (Smoke, small fires, blown fuses, bad or no sound) The damage occurs when the amplifier is playing loudly and the speaker is disconnected.
I suspect all of the noises were also present with the previous speakers, but if they were significantly less efficient would be less noticeable. Sounds like no harm done. All noises you describe are pretty usual, and are exacerbated by more efficient speakers.
www.kta-hifi.net |
#3 |
When people listen for a difference they are very likely to hear a difference, even if it is not really there. In this case a change of speaker is very likely to make a real difference. As kevinkr says, the most likely fault is clearly not present so don't worry. Try swapping back to the original speakers - but switch off this time!
#4 |
Thanks for the replies. My apologies, I should have said in the OP that the first thing I did when I noticed the hum was revert back to the original speakers which also then revealed the hum. I can categorically say it wasn't there before as I made a point of listening for it when I first received the amp.
The speaker change was from a £100 pair to a £350 pair of B&Ws which are supposedly revealing. I guess it's possible that as the amp "beds in" from new that it's character may change a bit, but it seems too much of a coincidence given that I mishandled it at the same time. At the end of the day though it still works ok (no smoke, explosions or otherwise!), but I just have this niggling doubt that I may have subtly knackered it a bit. Perception is everything though, perhaps I'm just not that impressed with the new speakers! So the specific risk of leaving on with no speakers connected is to the OPTs? I'm tempted to take the bottom off to see if there's anything obvious. Or maybe I should get out more! Kind regards. |
#5 |
As long as your amp was not actually outputting any music, no harm done. Don't lose any sleep over it!
Never send a human to do a machine's job. --Agent Smith |
#6 | |
But this is only when your're actually playing loud music over the amp while its output is disconnected. In the end, tube amps can stand quite some amount of abuse, so I'd be surprised if any lasting damage is done in this case.
#7 |
Thanks for the reply kavermei (and others). I set the volume to zero before swapping the speakers so hopefully no damage done.
Lightly tapping any of the eight valves is reproduced through the speakers. It's far more pronounced if the pre-amp valves are tapped compared to the KT88s. I don't know if this happened before as I didn't test it. Would you say this is normal? Apologies for the newbie questions, and thanks for the help. |
#8 | |
www.kta-hifi.net Last edited by kevinkr; 14th January 2011 at 05:53 PM. |
#9 |
Further to kevinkr's comments about microphonics - all tubes are microphonic - and every valve amp will add its own blancmange of microphonic distortion to the output. To alleviate this distortion you would mechanically (and sometimes acoustically) decouple the valves/valve bases/amp chassis from room and speaker vibrations. Sometimes a particular valve is annoyingly the worst offender - but it doesn't sound like you have such a problem at the moment. Most times people don't notice that distortion is being added, because it is below their perception threshold.
Ciao, Tim |
#10 | |
| Budget valve amp speakers | Knoffers | Full Range | 10 | 7th December 2010 07:12 PM |
| Strange damage on speakers | swak | Multi-Way | 8 | 15th July 2010 05:18 AM |
| Can Silicon Caulk damage speakers? | DeadSpeaker | Multi-Way | 13 | 19th January 2009 02:38 PM |
| newbie question:do i damage the speakers if this is the case? | digitaldiy | Chip Amps | 4 | 17th March 2005 04:16 PM |
| may PLOP sound damage speakers? | keyser | Multi-Way | 2 | 9th March 2005 10:12 AM |
| Page generated in 0.13367 seconds (86.62% PHP - 13.38% MySQL) with 10 queries |
