A non-shorting switch should be okay but it really doesn't matter if you are switching the input to the amplifier. A switch which shorts the inputs which are not selected might reduce the crosstalk from the sources which are not selected but if the inputs to the preamp are properly shielded and grounded, there should be no crosstalk.
