Old 13th January 2011, 08:57 PM   #21
taj is offline taj
taj's Avatar
Originally Posted by bottletop View Post
Taj, do you know what the score is on using GE Jan 6550a tubes in place of kt88? My gold lions test at Ip:71, Gm:8,300. The JJs test at PC:70, TC8. The 6550a are both different at PC: 49.8, TC: 5.9 and PC:42.6, TC:5.6. The chap at the shop with the tester said the 6550a's test as new but are not matched. So how can 6550a tubes be a direct drop in replacement for KT88 with such different PC and TC ratings? I did have a bad 12au7 tube that had a short on the same channel as the puffed resistor. Heard a buzz/hum through the speaker as well. Perhaps it was that.
The GLs had their plate current (Ip) and transconductance (Gm) measured at some operating point (voltages/currents applied to the various tube pins). The others were measured with some other system that I'm not familiar with, so I have no idea how to interpret those PC or TC numbers. I suspect PC is also "plate current", but I don't know what TC is (TransConductance using different units?), and we don't know what operating point it was measured at so, it's difficult to really derive meaning from the numbers or compare the GL's to the others.
Yes, that bad 12AU7 may have caused some downstream 'collateral damage''. It depends how bad 'bad' was ,what was shorted, and what the circuit looks like. But I'm no expert there either.
..Todd
Old 13th January 2011, 09:01 PM   #22
tomchr is offline tomchr  United States
tomchr's Avatar
Tom, yes you have described exactly what I am seeing. The grey anode plates are not changing colour at all. It is the part in the top top of the tube that is in the middle of the mica. Do you have any light to throw on the tube values above?
I don't think you have issues then. Sit back and enjoy the music.
If you post a picture, it would probably eliminate some of the guesswork, though.
I'm not intimately familiar with the KT88, but one indirectly heated tube is not that different from another in terms of basic stuff like heaters, cathode sleeves, etc. Not on an intuitive level anyway. I have some Sovtek 5AR4 rectifier tubes where the heater pokes out and glows bright yellow/orange like you describe. A google image search for "KT88 glow" turns up this: tube glow 2 | Flickr - Photo Sharing!. Does that look like what you're seeing?
~Tom
Old 13th January 2011, 09:19 PM   #23
Yes the JJ's look like that, if anything not as red through the holes. I have spent about 1/2 an hour now trying to upload a couple of images by going advanced. No joy as yet but i will get there. The GL tubes I have glow less on the top than on the tubes in the link you have sent.
Old 13th January 2011, 09:28 PM   #24
taj is offline taj
taj's Avatar
After you "Go Advanced", use the paperclip icon to the right of the font selector and happyface icon, which opens the attachment window. Browse to your image and select it, then click the upload button and close that little window and ...
..Todd
Old 13th January 2011, 10:03 PM   #25
Old 13th January 2011, 10:06 PM   #26
Nice one Todd! Well after all that I hope the images show the what I am on about.
Old 13th January 2011, 10:10 PM   #27
Thought you might want to see my modest set up. The phonograph does work but is not connected to the amp yet.
Old 13th January 2011, 11:05 PM   #28
tomchr's Avatar
The glow you have on the top of the KT88's is the heater glow. Nothing to worry about. Nice phonograph too. Now you just need a jack russell terrier to stare into it...
~Tom
Old 14th January 2011, 02:11 AM   #29
richwalters's Avatar
If youv'e got a tube behaving like in pic.....electron beam is concentrated on one side..it's a gonner. Came out of an inverted Fender amp and due to vibrations the cathode slipped in the mica causing misalignment. Manufacturer should have known better.
richy
Old 14th January 2011, 02:20 AM   #30
tomchr's Avatar
That looks like an unhappy anode to me. With the damage you describe, I'm not surprised.
~Tom
Post pics of your glowing tubes Pckid212 Tubes / Valves 97 25th October 2011 06:45 AM
Help, strange glowing in KT88 taotao Tubes / Valves 14 12th July 2009 08:07 AM
Problem: Really Bright glowing 6CA7 gary f Tubes / Valves 14 21st July 2006 09:42 PM
tube is flashing and glowing very bright! pho_boi Tubes / Valves 8 9th February 2006 09:16 PM
New production Tesla KT88 and 300B not JJ kgbamps Swap Meet 0 25th January 2004 04:12 AM
Copyright ©1999-2013 diyAudio
