diyAudio Sponsor
Old 11th January 2011, 11:39 PM   #1
manp111 is offline manp111  United States
Default Volume control resistance question? Step Attenuator?
I have a DHT preamp. It has a 100k ohm volume pot and I have to turn the volume almost all the way up when listening.
Can this be corrected with a lower resistance value volume control? If so, what value should I get, 50K, 25K, 10K?
I also want to replace the pot with a step attenuator.
Old 11th January 2011, 11:50 PM   #2
Banned
The short answer is no. Replacing the volume pot with a lower value pot will only worsen the situation.
Basically you haven't got enough gain in the system (insufficient voltage) or you have insufficient power driving the speakers. This is odd. Most modern sources (CD players, MP3 players) have ample output voltages, and you have a preamp anyway, which is intended to provide some signal amplification from e.g. a magnetic cartridge to drive a power amplifier.
Tell us what is in the rest of the system, from source to speakers.
w
Old 12th January 2011, 12:08 AM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
I second waki's short answer. Changing the volume control pot will not improve the situation.
A 47~100 kOhm pot should be fine for a volume control.
~Tom
Old 12th January 2011, 09:10 AM   #4
Mr. Triatic's Avatar
Waki´s right, worth to note is that a 100k pot and mr. Miller can throw a unwanted party and affect your amplifiers frequency response, you are better off with a 50k pot.
Still, if your amp is designed with a 100k pot i suggest you stick with that value and solve your gainproblem maybe with a preamplifier.
www.joddla.net/audio/
Would like to build simple volume control or attenuator Barry R Multi-Way 4 20th August 2005 12:28 PM
Passive balanced volume control using a single attenuator? Possible? ewildgoose Solid State 17 5th September 2004 09:58 PM
FS: relay volume control attenuator boards jwb Swap Meet 5 30th December 2003 05:24 PM
Volume Control via logrithmic stepped attenuator PaulHilgeman Solid State 4 6th February 2003 11:51 AM
Gainclome Volume Control using Log Stepped Attenuator PaulHilgeman Parts 10 5th February 2003 08:40 PM
Page generated in 0.07370 seconds (68.22% PHP - 31.78% MySQL) with 10 queries
