diyAudio Sponsor
Old 11th January 2011, 09:29 AM   #1
Default Transformer winding - mysterious!
Hi all! Not sure I post this in the right forum but since the transformer is to
be in my latest tube project...
I got a fried transformer from a friend. It's from an guitar amplifier.
The core size of the transformer will suit my current project perfectly so
I decided to take it apart and rewind it (as it had a short somewhere and have been cooked
real good).
It was welded together (all the E's and I's on same side) so I grinded the welds and it
was easily taken apart. All the old copper was stripped.
So I was left with the original bobbin and the E's (still all stuck together) and all the I's
(also still stuck together).
The transformer is an Engel brand btw.
As I have no clue what iron is in the core, I decided to try 1.2 Tesla in the
calculations. So permeability is unknown and estimated to handle the flux density.
Here is some data I used for the calculations:
Core size: 15.5cm2
Primary voltage: 230 VAC
Flux: 1.2 Tesla
Frequency: 50 Hz
Using the Xformer Designer by Particle I got 557 turns and doing it manually
(Coils and transformers) I got 550 turns.
So I went ahead and winded 560 turns (about 120 turns per layer and each layer
insulated with masking tape). I also wound 10 turns as a temporary secondary to meassure
the turns/volt. Then I temporarily assembled the transformer and just
placing the I-part on top (not welding it togehter yet as I only wanted to test the
primary, etc).
Connecting the transformer primary with a lightbulb in series to 230 VAC. Of course the
transformers hums a lot since it's not welded togehter now.... Now, what is now somewhat
confusing is that it seems like the idle current is very high since the lightbulb is
lighting up, even if just a bit dim. Since the transformer is unloaded it should not make the lamp shine, right?
And meassuring the secondary voltage (10 turns) does not show any voltage.
(It does emit a "surge" then power on and power off).
What is going on here? Is the transformer saturated?
Checking the DC resistance on the primary shows about 15 Ohms.
If I remove the I-part the lightbulb shines at full strength. That I understand since the "magnetic loop"
is then broken. And since the E and I is now only loosely coupled (not welded) some less efficency is expected.
But NO voltage at all on the secondary, AND the lightbulb shines more than I'd like it to?!?!
I also tried lowering the primary voltage using a variac, but no difference...
This is the first power transformer I wind the primary on (only done transformers with primary pre-made before).
*scratching my head, loosing all my hair*
Any ideas, anyone? I am sure I have missed something so go ahead and laugh and flame me for my stupidity! ;-)
Best regards // Jörgen Overgaard
Old 11th January 2011, 09:41 AM   #2
Default Stan
All I can think of is shorted secondary turns (most likely from end of layer to end of layer.
Old 11th January 2011, 10:50 AM   #3
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
how tight is the E held against the I's?, yup could be a shorted turn on the secondary...
Old 11th January 2011, 11:14 AM   #4
DF96 is offline DF96  England
If the Es and Is were separate, was it a mains transformer or single-ended output transformer? Is there a gap between them - this would reduce inductance?
Is it saturating?
Old 11th January 2011, 11:56 AM   #5
Hi all,
Thanks for the answers!
StanleyCaver: I will remove the secondary winding and check the results. I'll get back on that as I am at work now.
Tony: The E's and I's are held together as tight as I can press them together. I was thinking about forcing them together using a clamp. I will try that tonight. How sensitive is that by the way?
DF96: It was a mains transformer. I am not sure yet if it is saturating. If the secondary test winding is not shorted (will remove it and test without it) what
is left might be saturation right? But why is it saturating? Calculations tell the number of turns. And it should not saturate when I lower the primary voltage (to half or less) using the variac, right?
Anyway, I will start with removing the secondary winding. Then try clamping the E and I's together and see what happens.
Thanks a lot this far!
Old 11th January 2011, 12:02 PM   #6
trobbins's Avatar
I'd go with trying to clamp the I's to the E to reduce the effective airgap as much as possible (higher L, lower magnetising current).
I assume the weld you ground off was along the gap line, or parts thereof? If so, then the weld would also have contributed to a reduced effective gap (swinging choke concept, as the weld would saturate with any significant loading).
Ciao, Tim
Old 11th January 2011, 12:06 PM   #7
Tony's Avatar
clamping them thight is a good thing.....if i were you i'd use more turns on the primary if you have room for the secondary windings....you can still break them up (E and I's) into 4's or 2's if you have a grinder so you can separate the lams. then you can interleave the core stack back....would have been nice if you had a split bobbin....
in my case i usually apportion the primary and secondary coils as 50-50 of the available window...
Old 11th January 2011, 12:19 PM   #8
My guess is that you have a gap in the core. Power transformers normally alternate Es and Is to eliminate the gap. Your transformer used a weld instead. No matter how tightly you clamp them, you will still have a gap. Try repacking alternately. If possible, measure the inductance.
Old 11th January 2011, 05:57 PM   #9
Thanks for all the answers!
trobbins: I tried with the clamp. It didn't do very much difference. Yes, you are correct about the welds was along the gap lite. Good info there! Great!
Tony: About more turns on the primary... You mean more turns to lower the flux? If I go for 1 T it will be 668 turns instead of 557. That is better? Yes I read somewhere that one should always optimize for 50-50 on available window.
DF96: As I do not want to weld it back together before knowing if it will work, I think I will do as you say and repack it. Inductance is very low, about 0.6H. Not very good? I meassured another transformer (a lot smaller though) and it was about 3 H.
Also I meassured the idle current to be 150mA on the primary. Yikes! About 35 watts at idle and unloaded.
Anyway, everyone like pictures so here is one of the transformer while checking the inductance... And do not mind my very tidy workbench... It
it mostly clean..
Last edited by Overgaard; 11th January 2011 at 06:06 PM. Reason: Removed faulty image
Old 11th January 2011, 06:05 PM   #10
Ooops! Perhaps this will work.
Mysterious OPT winding tap Klimon Tubes / Valves 8 15th May 2009 10:06 AM
transformer winding gearheadgene Power Supplies 3 14th November 2008 02:52 PM
Transformer winding Tahmid Power Supplies 104 8th July 2008 07:56 AM
Mysterious UTC X-2806 / RCA 949426-2 Transformer snoopyma Tubes / Valves 4 21st December 2007 12:05 AM
Mysterious Output Transformer.... zxx123 Tubes / Valves 6 12th January 2005 09:05 PM
Page generated in 0.11870 seconds (80.07% PHP - 19.93% MySQL) with 11 queries
