diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   can anyone identify theses OT markings? (http://www.diyaudio.com/forums/tubes-valves/180916-can-anyone-identify-theses-ot-markings.html)
trigger 11th January 2011 04:58 AM
i have 2 transformers that were pulled from a large wurlitzer organ (i think maybe lowery?)
one of them is marked;
W.TT
117782
4573
the other;
p1.10
117782
2900
each has one white and one black wire and both look identical in make.
i was just trying to find out some specs on them, and way to test them?
thank you much
aardvarkash10 11th January 2011 05:36 AM
sounds like chokes, not transformers...
trigger 11th January 2011 06:31 AM
yeah chokes.
umm excuse my noobness but what is the difference between a choke and output transformer?
aardvarkash10 11th January 2011 06:36 AM
a choke is a single winding inductor - one wire in, one out.
Typically it is used in a power supply to smooth the ripple in the supply.
A Transformer has two (or more) windings and typically is designed to match the voltage (or impedance) of dissimilar supply and load.
trigger 11th January 2011 04:47 PM
thank you for clearing that up, any clue how to test the henrys? on the choke?
Tre' 11th January 2011 09:22 PM
How to Measure Inductance
Copyright 1999-2017 diyAudio
