| diyAudio Sponsor | ||
Hi All,
Having read these resent threads: #26 pre amp WE417A Valve Preamplifier Tube heaters AC or DC? I would like to ask you gurus a few questions please.... If I understand the threads correctly, a DHT pre can provide a lower signal to noise ratio. Could this therefore provide a solid basis for a high performance line level pre amp with a phono stage? Maybe using these ingredients; Salas shunt HV, Ros coleman Regulators But using more easily available components than the #26 valves? I realise they may be a drop in performance, but I tried to find one of these valves, it was expensive. What valves could be used, good, common type to allow changing within the same family of valves. But still provide very good performance? Does anyone know of any kits available? Many thanks Ian |
#2 |
Hi Ian
DHT has more noise level than indirect heating tube and less gain but more emotional feeling and transparent. good for line stage with a out put transformer, 300B is the best in result if you don't think it is a waste. Phono stage needs more gain,at least 2 stages of mid or high mu tube, 6922 in mu stage with a LCR RIAA filter is a hi-end quality design cheers tony ma |
#3 |
Thank you Tony ma.
What circuits or combination out there would you recommend? I was hoping to build a single unit, thinking it might save building two separate power supplies? Thanks Ian |
#4 |
Always good for a read... Direct Heating
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#5 | |
Separated power supply always has the better sound only cost more, in line stage very simple you can use just same as a single end power amp's design but in 600 ohm out put and a DC filament power supply is needed if for DHT Phono stage you can search for Shishido's design 6DJ8 with a 600 ohm LCR RIAA filter, this is a very Hi End design cheers tony ma |
#6 |
Hi!
If you are on a limited budget, a DHT preamp is not the right choice IMHO. If you are willing to spend the best possible parts a DHT preamp is great! If not you will get better results with IDHTs. While phono circuits with all DHTs are doable (I've done that) it takes a lot of effort and it will be BIG! Also I'd advice not to start with a DHT design if this is your first preamp. Better gain experience with some IDHT circuits first before you dive into the DHT preamp waters. Best regards Thomas
http://vinylsavor.blogspot.com/ |
#7 | |
Hi!
Best regards Thomas
#8 |
If you are looking at DHT small-signal amplification, go find Andy Evans. He has more experience in this area than anyone I know.
Poinz |
#9 | |
I did try that circuit but I changed the cap to Solen, The sound not bad compare to most SS phono stage or tube with CR filter only, may be Tango's RIAA filter unit sound good, but now I already changed to WE437A SE to Tango's LCR unit with transformer coupling and 5876 pencil type tube in out-put section with transformer too cheers tony ma |
#10 |
Hi Tony,
Yes I believe that it sounds better than most SS phono stages,but it won't reveal what is possible with LCR EQ. I dissmissed Solens a long time ago BTW, did not like them at all. I build my LCR phono stages all transformer coupled with tubes like EC8020, WE437, E810F, E55L, D3A, 6AM4 Thomas
| Using MiniDSP's in a pre amp.. ideas. | jaistanley | Digital Line Level | 2 | 24th November 2010 07:01 AM |
| A PCB-design for Phono-pre-amp | Roushon | Analogue Source | 19 | 17th May 2010 05:41 AM |
| All DHT Phono Stage | Steve Cresswell | Tubes / Valves | 20 | 31st July 2009 05:03 PM |
| Pre-pre; phono; pre line ;device discrete (bjt/fet) o op. amplifier | GIPIONE | Solid State | 8 | 18th December 2005 09:09 PM |
| Phono Pre-Design Input | philipbarrett | Tubes / Valves | 22 | 5th November 2005 04:20 PM |
| Page generated in 0.11459 seconds (79.43% PHP - 20.57% MySQL) with 10 queries |
